Digital HID 55w kit from Lightwerkz.net
Has anyone else purchased this kit on here? If so has anyone experienced one light fireing up for a second and then turning right back off? Also has anyone ever seen a light flashing/strobing even when the lights are turned off??? This is what I am experiencing with this kit, and I think I can say that its not the balasts or bulbs because I have seen one light fire up for a second and then shut back off on both sides. Now I do have a wire harness that didnt come from lightwerkz, it was a harness from ebay, is it possible that the harness cannot handle the 55w kit? Or is the whole kit just possibly crap? I hope not for $180...
It's really hard to say. Have you switched bulbs around to see if it is the ballast or not. My MobileHID kit is 2 years old and the ballast on my driver side is beginning to go. Every now and then the light will just go out or when I turn it on it will go off after a second. I tested with another ballast I had and the light stayed on so that's how i knew my ballasts were dying.
You have the same problem i had with my bike about light flashing and this is due to alot of power going into the light system . You have to make sure that your relay kit is actually working and if this is not the case then your hid 55w ballast is mad or a lemon . I sell HID at my job all the time and sometimes you see them flashing and when we change ballast everything seems to work just fine.
S7ephavs
03-22-2015 12:09 PM
jaspercanda
12-28-2014 10:09 AM
umnitza
12-01-2014 06:26 PM
