got my fogs done and more
so today i had nothing to do, so i decided to spend the day playing with the car. I ended up getting alot done
the list lol-
mount hella micro de foglights
install 3000K HID's into fogs
install led strips into headrests
install more led strips in engine bay
wired in my front footwell cathodes (i forgot when i rewired the car last weekend)
swapped door pocket led's out for cathodes
fixed a rattle i had behind the driver side rear seat panel (loose bolt)
fixed my whelen strobe light pattern switcher button (the solder broke)
and i think that's it.
i'm not very happy with the HID's. everything said 3000k H3's. they're H3's... but they're nowhere near 3000k. They look stock halogen color versus the yellow they should be.
everything else is great
before-
the list lol-
before-
oznium flex strips
to get them to fit, i had to cut them though. phil said as long as you cut every 3 led's, your fine. for good measure, i dabbed some silicone on the cut end.
haha yeah, i went out for a drive yesterday evening with just the fogs on. it's bright enough to run with just the fogs and no headlights :-P
there will be more blue once i get back to orlando (im home in port st lucie for thanksgiving). I've got 8 more led strips to put in the wheel wells ;)
if you take off the rear panels, you'll see that the inner skin is held together by a couple of 10mm bolts. One of the bolts came loose and allowed the 2 pieces that bolt was holding together to rattle against each other when the music was turned on.
thanks for the comments guys
