Headlight sealant
Headlight sealant
Just wondering if anyone knows where to buy the same product used to seal the factory headlights, or at least a similar product. I've opened the headlights so many times that I am running out of sealant, and apparently one of them didn't properly reseal the last time. I need to add some more sealant, but I don't really want to mix silicone with the sealant which is already there. I would like something with the same properties as the current sealant, so that I may open the headlights again in the future if necessary. Ideally, just the same product. Anyone know what it is?
Originally Posted by captainlaziness
Silicone is not the same. Silicone is heat resistant.
this is pretty easy........call up a local autobody shop.....as them where they get their supplies from.......there is always a local supply shop..........for instance I live in Tacoma Wa.....the nearest supply store is 4 miles from my house.........they also have all the door and panel pins......high grit sandpaper....polish.....buffers.......body tools........port a power.......spitzenagls......lead bars.....everything.....and every other tool known to man once you find the local shop tell them you need to seal your headlights and need the heat activated sealer........they have it or can get it......stuff is like $10 a tube.......and it is grey like stock........more commonly used to seal up body panels in trunks and firewalls........
atlantaemail
09-20-2015 03:03 AM
