HELP: With my Third Brake Light....
Hey guys,
My stock third brake light isn't lighting up completely. When I step on the brake the third brake light lights up, but hardly noticeable.
Could this be a loose plug or are my led's burnt??
Thanks for any help,
^Sorry should have been more clear.
It's a stock tbl, so only the middle is suppose to light up. The problem is when I step on the brake the tbl hardly lights up. You can't see the tbl light up unless its completely dark outside and you stand a couple feet in front the the tbl.
Could this be a loose plug somewhere or is it time to replace it?
The last thing I had installed is my Viper 5900 with 2 529t's.
open up the hatch and take a look........there area two screws on the hatch cover inside,remove the trim around window inside and give it a yank by the handles and it will come right off,takes like 4 minutes,look for loose plug,if nothing works you need new light.......
the tbl is a set of several led's so they wouldn't burn out across the entire brake light. i checked my fuses and they are good. it has to be something in the circuit board they led's are attached to but i was really hoping to not have to replace the whole thing.
Klashan
09-24-2015 01:39 PM
