How Do I paint my Heat Shield Properly?
Old 08-13-2008 | 03:00 AM
deverse's Avatar
Default How Do I paint my Heat Shield Properly?
I just painted my heat shield with VHT high heat paint and before I painted it I sanded it with 400 grit sand paper. It seem to be flaking a little bit. How long am I suppose to wait before installing when it finish painting? And did I needed to primer it before painting? Thanks!
Old 08-13-2008 | 03:21 AM
BZinn1's Avatar
sand shield,clean shield with alcohol..........wipe down good.........plastic adhesion promoter is best to get paint to stick........but primer does ok.......several coats sandin in between........paint with high heat paint.....clearcoat .......let it sit for a few days to cure well......then install.
Old 08-13-2008 | 06:12 AM
aen's Avatar
aen
don't even sand it, too much work. it's just a piece of metal, get high temp paint. if it peels, do it again
Old 08-13-2008 | 02:14 PM
rob35aaa's Avatar
i agree with aen hahah
Old 08-13-2008 | 02:41 PM
chicotunner07's Avatar
i used some sandpaper that i found laying around(fine grit i remember) then cleaned off with water, wiped dry, used high heat primer, and high heat gloss black
running 5 months with no signs of peeling or discoloration, i even pressure wash it every now and then
Old 08-13-2008 | 02:42 PM
oh yeah, i let it sit in the sun on a 90degree day for about half hour after each coat
2 coats of primer
3 coats of paint
Old 08-13-2008 | 03:13 PM
Scoobasteve4132's Avatar
VHT makes a hi temp primer for their hi temp paints!
Old 08-13-2008 | 03:31 PM
Fhe1079's Avatar
I used the 1200 degrees one and it's has been good for about year with no chipping or cracking. All I did was sand it and spray it with 2 coats.... Then follow the directions for baking it in the oven to get the curing right.
Old 08-13-2008 | 03:49 PM
most hi temp parts can be cured installed!... like when my turbo manifold was jethot coated... it started smoking then after calling them they explained that it was normal... its part of the curing process...
Old 08-14-2008 | 04:06 AM
its tru, the heat of the exhaust manifold will cure it in a way, and once it cools completely it will be as if it was done in an oven
Old 08-14-2008 | 05:57 AM
Dr_Isotope's Avatar
Or you can use a propane torch to pre-heat the metal before you paint. I do one coat of Duplicolor 500º on hot metal. Done. Zero prep.
Old 08-14-2008 | 06:26 AM
BZinn1's Avatar
ooops he said heat shield......some how i read valve cover shield.....yeah just clean it and high temp paint it and it will be good.....LOL
Old 08-14-2008 | 01:51 PM
the Docs idea sounds great!!
would that work for any metal? Im guessin yes
k1114
43
03-01-2023 04:08 AM
RS2Blitz
01-15-2016 10:41 PM
VitaminE
18
07-02-2015 09:10 PM
the90am
06-19-2015 09:04 PM
xa007xa
02-22-2015 04:05 PM
Quick Reply: How Do I paint my Heat Shield Properly?
