How to remove the Driver side fender
This is the 3rd time
3 or 4 10MM bolts between the fender bend and the hood (engine bay sides)
1 or 2 10mm bolts under the side skirt so you need to just separate it from teh front of the fender (a 10 mm bolt on the side and a few buttons that u need to pop out from underneath)
Then theres a 10 mm bolt in the door jam behind the door hinges. You'll need an extension for that.
I dont remember but you might have to remove the head light which is only 2 10mm bolts that also have grooves for a philips screw driver.
I might be missing something but its been a while.
mischadoll
03-09-2015 05:48 AM
