:( I lost control :(
Old 06-13-2006 | 06:14 AM
fishingexpert87's Avatar
Default :( I lost control :(
Well, i was driving and coming off the turnpike to get to my scionevolution club, and i was making my final left turn, my tires acted stupid on me and had to go cheap. so i basically skidded out of control and hit the median infront of me and jumped onto the other lanes and it turned back and i landed back ontop of the median. thank god i didnt hit n e one or n e one didnt hit me. i thank God that im ok and everything because i know it could have been worse. My tires are the worst, never buy kumho ecstas, the slide for no apparent reason. i will never buy from kumhos again. well heres a few pix of the incident:
Plz if your a mechanic or something, could you tell me how bad this thing is? like will it cost alot to fix and do you know whats broken? i took pics of behind the rims:
thank god for seatbelts too
Old 06-13-2006 | 06:16 AM
exige's Avatar
jesus man....thank god you're okay....is it just the tire thats screwd up or is there bodywork screwd up too?
Old 06-13-2006 | 06:17 AM
thanks, within all seriousness, im hoping its just the tire, but when i drove it a bit to get it off the median, the rim kept rubbing on the fender
Old 06-13-2006 | 06:20 AM
exige's Avatar
i wish i knew more about this stuff...sry!
Old 06-13-2006 | 06:22 AM
nah dont worry, i just hope its nothing too much to worry about
Old 06-13-2006 | 06:30 AM
BlkTC's Avatar
oh my! wow.. sucks dude.. hope it gets better! tkz
Old 06-13-2006 | 06:43 AM
DTRUONG_112's Avatar
that sucks man
io333's Avatar
You've got some structural damage. The bill is going to hurt. Sorry. I learned years ago that before anything else, tires are most important.
Old 06-13-2006 | 06:48 AM
wheres the structural damage? the people that came to help me were from the scion club too and they said it wont cost too much. they said i should look in a junk yard for a tc and get one off of that and i shouldnt be looking for over $400 to spend
Old 06-13-2006 | 06:53 AM
uber-xA-RS2's Avatar
I think what you have there is a bent lower control arm, and wheel. I say lower control arm because I had a minor "mishap" on the road in November with my xA.
Essentially I spun out a smacked a telephone pole with the passenger side front fender and my wheel took most of the impact. Afterwards I had the same problem as you, minus the flat tire, and after I did an inspection I found my lower control arm was shaped like a "U".
You may have some other damage in there, so I would have a professional look at it first.
Old 06-13-2006 | 06:55 AM
oh ok, yea for sure im gonna get it checked, how much did it cost for u to get that fixed?
Old 06-13-2006 | 07:02 AM
miamibusta69's Avatar
took that turn at 55 mph with the pedal to the floor! THIs is the second friend that has bought rims and used the crappy tires they come with.... GOOD they you are both alive !
p zero nero baby!
if you want to look for parts one day let me know! AND finish my center console now that you cant leave the house......
O yeah and screw rooms to go trying to run into your car while it was on the side of the road
Old 06-13-2006 | 07:06 AM
^^^ lol he was ahead of me, and no i wasnt going fast at the turn, im not stupid enough to make a fast turn on such a small closed space.
and yea people in miami are stupid, instead of them coming out of their car to see if im ok, they just stop to look and they drive away. god i hate gawkers. and the stupid truck for roomstogo almost hit me from behind, called the number on the back of the truck, maybe they will give me free furniture or something.
Old 06-13-2006 | 07:07 AM
Krayzie_Los's Avatar
possible: upper strut damage, strut damage, upper and lower control arms, cv axle, check for any frame damage, sway bar damage, rim and tire of course....and add if any body and paint damage
might also want to check for any under carrage damage too
Old 06-13-2006 | 07:09 AM
i looked under, i didnt see any cracks or anything, no paint chips, no dents, i kno the tire is gone for sure because i even heard the air come out.
Old 06-13-2006 | 07:34 AM
TCpete's Avatar
dam dude i head about this at the meet. im glad to see that you are ok and thats the most important thing. as far as damage to the car.
1. defenitely strut,axel,sway bar and component damage.
2. you also have some frame damage at the strut area because your shocks are pushed back to the door and the wheel is not centered.
3. LCA and UCA damage. i can tell by the stress on the LCA especialy
4. you might be lucky but also your axle looks fried and i would check also on the other side as you seemed to have taken a direct impact from the side which might haved shoved the engine over or given the axle housing a good wack.
from those pics that looks like that sums it up. if i was there i could tell you more.
mostly like also you will need to replace the entire assemblye from LCA to UCA for safety reasons as im sure also your rotor and caliper took a hard blow.
hopefully you have a good insurance company. the damamges are pretty bad but can be fixed with the right shop. i hope all goes well for you and if you need any parts info or good shops to help LMK.
also get rid of those tires and buy some flaken azenis, toyo proxies, yokohamas or pzeros.
Old 06-13-2006 | 08:49 AM
sciontc313's Avatar
kumho
Old 06-13-2006 | 08:55 AM
legionscion's Avatar
damn that suck i had the same problem like 2-3 years ago you are going to have to replace all that side and where your shocks conect to the body see if it damage, if i was you call your insurance to fix it it will be alot cheaper tooo
Old 06-13-2006 | 12:27 PM
Scion-ce's Avatar
if you ain't outta control, you ain't in control
Old 06-13-2006 | 12:34 PM
raWr215's Avatar
good thing you are safe; but, don't you think you was going a bit too fast? be safe buddy, drive safely
