Kaminari install tips and advice
Old 04-22-2008 | 07:10 PM
eddie200112's Avatar
Default Kaminari install tips and advice
Hi, seems to be limited and scattered advice on the subject across the forums.
I just bought a Kaminari kit via Viniati.com. i have had it fitted and it fits good but the front bumpers top lip , where it meets the hood seem to stick out furter on the driver side than the passenger side, my body shop said there is not much that can be done about that, so should i contact kaminari, like did i get a crummy kit, or is it something i just have to live with.
Also, i would love install advice considering the kit did not come with a install manual, just a bunch of bolts and advertisement brochures.
Ive heard of the plastic sheild issue with the front bumper, but ne thing else is there a better way to keep the sideskirts held in place other than screwing screws into the top of them. what bolts do i use for the front and rear bumper thx all
Old 04-22-2008 | 07:22 PM
Scott8's Avatar
is it real Kamanari, or is it Viniati's knock off K kit?
Old 04-22-2008 | 07:27 PM
it should be from kaminari they are the ones that made it they even called me from kaminari when it was finished
Old 04-22-2008 | 07:30 PM
Old 04-22-2008 | 07:31 PM
Old 04-22-2008 | 07:32 PM
Old 04-22-2008 | 07:54 PM
Scoobasteve4132's Avatar
Give Kaminari a call... See what they have to say...
Old 04-22-2008 | 08:18 PM
shows the difference in the lip on each side
Old 04-22-2008 | 08:21 PM
the top lip anyway next to the hood u can see the driver side stick out a bit more
Old 04-23-2008 | 12:05 AM
rvpps2rocks's Avatar
ouch ...the only thing i can think off is the way its mounted....its only plastic clips. so im not really sure what to tell you. GL though
Old 04-23-2008 | 02:00 AM
BZinn1's Avatar
That is indeed a little off......not much though and if you adjust the mount for the pins on the top at the front you could get it to pull back a small amount.....also adjust out the passenger side as well and it will get closer.........body shop should of been able to make those minor adjustments........
Old 04-23-2008 | 04:19 AM
ya the shop iwent to decided they didnt want to put the kit on so they may have just slapped the bumper on to get me out of there, im goin to a new shop on the 1st to have the install the kit
Old 04-23-2008 | 06:07 AM
BZinn1's Avatar
the mounts at the top are kinda loose and you can use shims like a rubber grommet to pull the kit back and push it forward as needed total cost...... 20cents...........sometimes non stock body parts need persuaded just a little bit to form properly.......once it is painted the differance is going to be even less....you can also move hood just a bit to compensate.......small moves make big changes on body panels.
Old 04-23-2008 | 06:47 AM
iKONA's Avatar
I have the same problem. Its a tough thing to fix with out reconstructing th whole lip. I was on my way to doing it but its not worth it. It would take a long time and if you had somebody do it it would cost quite a bit. Im ok with that little 1 - 2 cm difference. Overall the kaminari is a great fit. If you really want it to be good.
Here are 2 things you can do. One of them you can do yourself and isnt hard at all. Open the hood, loosen all 4 bolts, and have somebody hold the hood levle with the ground and pull it to shift the hood out a bit. Itl only go maybe a few mm if that. Then tighten them back up, the gap between the fenders and hood wont be noticable and if it is you can loosen the front fender bolts and move that out and your fine.
If thats not enough get a shop build the hood a little longer by adding fiberglass to the front. Itl look natural and should hold strong.
Old 05-13-2008 | 05:31 AM
ok the shop got it all painted and installed
only problem is that there are two dimples in the rear bumper!
they said that was from it buckling during install and theres nothing they can do about it.
shouldnt they have filled those and smoothened them out before painting.
do i really have to settle for that?
Old 05-23-2008 | 08:17 AM
ok its all done feast your eyes
Old 10-12-2008 | 06:29 PM
tCtCtC's Avatar
im sorry to rise this thread, but ur pics on ur tc inspire me soooo much to get the kami body kit. theres just something about it.... that makes it look so beautiful
Old 10-12-2008 | 06:47 PM
XionLion's Avatar
put a drop on it.... its to high
Old 10-13-2008 | 12:43 AM
Default reply
you kidding me its hard enough to get in and out ofthe drivway as it is with this kit on
Quick Reply: Kaminari install tips and advice
