my freakin sunroof wont close!!!
i just had it open for like 5 min while havin a cig and when i tried to close it, it autimatically rolled back to where it was at. and i was like WTF!? (that's when the car was sittin still) and drove with it open and while driving, i tried to close it again and at that time, it closed........what the hell's wrong with my roof man!!!
can anyone help????
can anyone help????
Could have been something in the ruts that caused it to go back and not close . Interesting as I have not heard of this until now on the TC . Does it now work while sitting still ? If still under warranty and is working ok , call the dealership so they know about it in case it quits working after the warranty period .
while sittin still it won't close on it self, i had to hold down the wind defelctor in the front of the roof down so that my sunroof can roll on top of that, while i'm drivin, i guess it's easier for the sun roof to close because wind actually pushes down the deflector, tha's my theory.... would that be covered under warranty
I had the same thing, started when the weather got really warm. It would hit the support struts for the deflector and retract. I asked them to look at it one day when I had my oil changed and 10K service done, and it took them the entire day to "reset the computer." I don't know what that entailed, but they must have disconnected my battery as my radio was goofy etc.
It has been working fine since then.
Mine also did the same for two days this past summer. It would stop about 3/4 of the way when I rolled it in. And then it would stop and go back. I haven't had any problems since. Kinda wierd.
I had the same problem and took the car in and they had it for a few hours they had to clean the tracks and re-lube them the grease had dried or been wiped off from cleaning. No big deal at least you know you can't cut your head off if you try to close the sunroof with your head out of it. LOL You'll live.
mine a few times has not wanted to open at all. i'll press the button to open and it wont, i'll keep pressing it a bunch of times and then it will open, or sometimes it will start to open, but wont until i press the botton alot again...
Mine was doping this, it was a simple thing for the dealership to clean and adjust it since it was under warranty. If you NEED to have it closed you can roll down your drivers window and gently push down in the deflector while you are closing the roof. It will close then. It's when it tries to push the deflector down itself that it senses too much forse and opens again....
BlingSlade
10-19-2016 01:39 AM
atlantaemail
09-20-2015 03:03 AM
