new HIC Scion tC roof visor
#381
after reading some other members problem with it sticking, i went outside to double check mine, the right side was coming off as well. I cleaned it with alcohol prior to installation.
#382
#386
hmmm, so rennsport your trying to tell me that i didnt install it correctly?? im going to go ahead and try to warm the adhesive up with a blow dryer while its already installed and push it down a little harder on friday.
#387
I'm not saying you installed it wrong. can you post some photos? thanks
#392
Imma try to redo it, I was thinking that using some wider double side and sticking it closer to the inner part of the spoiler can probably protect it from the wind. Imma do the heat gun thing too
#395
i doubled check mine,mine was fine,i did let it sit for a little bit prior to driving it,i made sure it was sticking on the hatch window,i doubled check like 10x times LOL..pressing down on it to make sure,
#396
check it again because I was thinking the same thing when i pushed it back down, I tried lifting it and everything but it wouldn't move then after like 2 hours that damn spot lifted up again and when i just gave up after 2 more tries i took it off, it came off VERY easily.
What would you guys recommend me doing? Applying the hair dryer over the visor where the 3m is located or completely take it off and use the hair dryer directly to the 3m tape then re-paste?
I would rather just do the hair dryer over the visor but you do yall think it might warp the visor???
#397
i would just heat up the visor a bit. that would in turn heat up the adhesive. i guess installation really does matter for this. it gets harder to re-adhere the roof visor to the glass after it's been exposed to external elements, so as a last resort, i would cut off the tape from the end , and maybe stack 2 fresh 3m double stick tapes to replace it.
One thing I do notice from the ones sold for SC's, is that the ends do tend to come loose, but the rest of the roof visor is so well stuck on there, no one really gaf about it.
So to those who haven't installed it yet, wipe down with alcohol before, and make sure it's super dry.. heat up the adhesive (if you're not prone to over-doing it, heat gun will be fine), stick it on as rennsport mentioned, and then push down for a good while on it.
#399
lol people that are trying to use cold 3m adhesive, in the cold arent very bright. Cold 3M double side tape looses almost all of its potential strength when its cold. You need to heat the tape up by using a low temp heat gun or a hair dryer. This way the tape can become more flexible and allow itself to use more surface area to cling to the window. Hope that helps.
