Nokya Headlight Bulbs Arctic White Stage 2
Old 06-02-2007 | 01:05 AM
Sciontc0680's Avatar
Default Nokya Headlight Bulbs Arctic White Stage 2
I am new to this site. I went to a speed shop and bought a pair of High and Low beams for my 06 TC. I installed them and the 1 low beam will go on, but after they have been on for awhile it goes out. The Bulb still looks good. I need Help!!! Has anyone else had a problem like this
Old 06-02-2007 | 01:14 AM
SSQ's Avatar
SSQ
no, but you might want to check:
-if the filament is still in one piece, if not, the bulb is burnt
-if you touched the glass during the installation, if you did, wipe with rubbing alcohol
-check the socket of the bulbs to see if there are any melting of any sort.
does it turn on every time but always shuts off?
Old 06-02-2007 | 01:28 AM
The filament is still in one peice...
I have not touched the glass..
Would I need the wiring harness?
Old 06-02-2007 | 04:56 AM
esisso's Avatar
i would definitely check your wiring...aftermarket bulbs can melt your existing harness if you dont upgrade it
Old 06-02-2007 | 04:57 AM
SSQ's Avatar
SSQ
Does it always turn on but just shuts off some time later? Or did it just quit for good?
What is the rated power draw of the bulb?
Just like the guy upstairs said, certain aftermarket bulbs can melt your wiring harness because of:
1. high power draw from your existing wiring
2. arcing from bad connections
Your stock wiring shouldn't be put to anything more than ~62w, and most 9006 bulbs are rates at 55.
However, I have heard pretty good things about the quality of Nokya bulbs as far as the construction goes. Light output and life is another story.
Old 06-03-2007 | 12:45 AM
All I know so far is that, I had put the Bulbs in And they both worked. !hour went by and one went out. So then i was trying to see what had happened. I took the bad bulb out and switched it with the good one. That one worked. The next day I went back to the speed shop and the guy gave me another one to put in. It worked. By the time I got home later that day the bulb was out. The new one that i had replaced.
The New bulbs put out 100Watts Rated 7000k
Should I get the wire harness and try that? I went to the website and it said to use the wire harness.
www.nakyausa.com
Old 06-03-2007 | 12:47 AM
SSQ's Avatar
SSQ
At 100W, yes, you would really want a wiring harness.
Old 06-03-2007 | 12:59 AM
I will try that. Thanks. Would you know about how much they cost from nakya?
Old 06-03-2007 | 01:16 AM
SSQ's Avatar
SSQ
No idea. I an not sure if it will help with anything unless it replace the entire stock harness.
HeyyJose
03-11-2015 03:15 PM
Cadillac15
01-29-2015 08:34 AM
Itsdchz
06-30-2009 05:54 AM
jjambox
11-26-2003 09:32 AM
BCS
10-12-2003 10:52 PM
