Nokya Magnum Cosmic White 80W (5000K look)
I too put some of these lights into my xB Nokya Arctic White (H4 bulbs). I like the way they look soo much better than my previous ones that were similar to silverstar.
Hope these things last me though. Let us know when your's burn out if they do.
I'll try and get some pics later and post them.
Will do. I do a lot of night driving and now with winter, I get out of work around 6, so it'll be dark already. I would expect them to last just as long as silverstars b/c of the higher gauge harness allowing them to burn at a higher wattage without extra fatigue. Again, that's just what I think. So, we'll see.
15$....definately worth it............your light might actually be dimmer right now than it will after the harness....it allows more power into the bulb easier...............maybe only noticeable with a lumen reader but still noticeable.
I thought yours looked a little different than mine. Mine are more white/blue instead of purple/white. I like them either way though.
Whats cool about the ones I got is how blue the acutal bulb is. When the lgihts are off the healights looks really blue. :D
Sweet, thanks.
Mine are more of a crystalic purpleish type of bulb. Mine are also a little more emphasized due to the headlight protection film I have. It amplifies whatever the more powerful wavelength is and produces that glow of purple in my case.
Originally Posted by D_M_A_N
Mines 100/120 and I have it plugged into the stock harness... i will be getting the better harness tho'
100/120 watts?!? Are you concerned about the extra heat from the bulbs?
i dont beleive that wattage number of any aftermarket bulb company till you show me the amperage that they draw w/a voltmeter in line..
problem is you need stock/w/ these in the same photo, one on each side and then a shot on the wall, then a shot at night from like 100yds back... that way we can realy see how they are.. especialy output wise
