Problems with my HID + VRD Fog
Old 09-27-2008 | 08:37 AM
scionaruba's Avatar
Default Problems with my HID + VRD Fog
OK, I hooked up my HID kit on the VRD harness without a problem,
but most of the times only one side lights up.
When I push the switch they both light up but then the left fog goes out.
It takes a couple of try before it stays on.
Anyone have any idea what may be causing this?
Old 09-27-2008 | 08:48 AM
ihavenosn's Avatar
Sounds like it might be a problem with your ballast, have you tried contacting the person who sold you the hid kit? Also post up info on the hid kit as well so other people who have it can chime in on their experiences.
Old 09-27-2008 | 08:58 AM
scionaruba's Avatar
The kit is from Umnitza.
It's a 55W Digital Slim Kit.
Old 09-27-2008 | 09:16 AM
TylerC08's Avatar
The 50W kit...?,
I've been talking to him about my 50W kit lately...
He responds pretty fast so you should have no problems with getting it worked out.
Old 09-27-2008 | 09:55 AM
mcheng08's Avatar
do you have any wire harness?
Old 09-27-2008 | 01:57 PM
scionaruba's Avatar
I have the stock VRD Fogs wire harness.
Old 09-27-2008 | 05:52 PM
muuunkeeyy's Avatar
slim kits usually mess up. ive had experience with slim kits for myself and my friend. they were both 35w and sometimes they dont light up. i went and got the same kit with big ballasts from the guy and then it works fine. one friend had big which work fine, and the guy with slim had problems with the bulb igniting. i'd stay away from slim kits.
Old 09-27-2008 | 07:15 PM
mcheng08's Avatar
i mean do you have a harness for the HID, black ground wire and red wire connecting to the battery? I had the same issue like you, when i push the power button only one would turn on and after a few tries both would turn on. This usually means that the HID kit is not getting enough power, getting a wire harness for the hid kit solved my problem.
Old 09-27-2008 | 07:18 PM
muuunkeeyy's Avatar
isn't that for relay?
Old 09-27-2008 | 07:25 PM
mcheng08's Avatar
wire harness same thing like relay...
Old 09-27-2008 | 07:27 PM
muuunkeeyy's Avatar
^ some people don't use the relay. i didnt.
Old 09-27-2008 | 07:31 PM
mcheng08's Avatar
i see, but maybe scionaruba needs a relay/wire harness that might solve his problem, sounds like power issue.
Old 09-27-2008 | 07:51 PM
scionaruba's Avatar
I didn't get a relay/harness when I got the kit but the VRD wire harness has a relay.
Any help on how to wire that extra relay/harness or where to get one?
Old 09-27-2008 | 08:05 PM
mcheng08's Avatar
Do I really need another relay/harness?
Any help on how to wire that extra relay/harness?
The one that came with the VRD is not enough
1. Visit this website http://www.mobilehid.com/scionlife
2. Scroll to the bottom and look for this "One H1/H3 wiring harness- $20 shipped!
3. Buy it
4. Hope these pics can help with the install
Old 09-27-2008 | 09:08 PM
muuunkeeyy's Avatar
i still think its a ballast issue. small ballasts usualyl fail. ive tried them 3 times and they all failed. 2 different companies.
Old 09-27-2008 | 09:22 PM
TylerC08's Avatar
The slim ballasts I have seem to be prone to certain 'shocks' under normal driving conditions. I keep getting weird bulb pattern vibrations with mine but every time I relocate the ballasts, they seem to react differently. Seems to be a combo of bad bulbs and ballasts...who knows.
Old 09-27-2008 | 11:22 PM
scionaruba's Avatar
I don't know about that......
I tried each ballast on there own and they did light up without a hitch individually.
The problem seems to be when both need to light up together.
Old 09-30-2008 | 10:23 PM
scionaruba's Avatar
Ok... I ordered the Mobile HID relay/harness.
I'll let you guys know if it solved my problem.
Old 09-30-2008 | 10:25 PM
TylerC08's Avatar
^waiting.
Old 10-11-2008 | 07:49 PM
scionaruba's Avatar
Ok, I got the relay / harness installed and it did solve my problem.
:D
