remove fender
Re: remove fender
Originally Posted by ISTCIONI
does any one know how to remove the scion tc front fender? i have a dent and im going to try to knock it out from the inside...thanks
There are 3 main screws that hold the fender on (besides the ones under the hood).
First pop-off the plastic corner piece next to the mirror- 1st screw is under it
Now you have to remove the front bumper to get to the 2nd screw which is underneath the headlight.
After that remove the side skirt (or at least the front part of it) Under it is the 3rd screw.
Then take off all the screws that are along the fender under the hood. Plus 2 headlight screws connected to it.
I hope this helps. If not ill try and get you some photos if i can.
Good Luck!
dont forget the ten mil in the inside of the fender... like said before... three under thehood on top of fender, one behind the cover next to mirror.. one holding the bottom of the fender under the sid skirt... one under the bumper holding on teh fender... and one inside the fender .. you will need to fold back the wheel well to get at this one...
