removing and re-applying rear emblem
Old 02-10-2008 | 07:00 AM
captainlaziness's Avatar
Yup.
I just reused what was on the back of mine. I took the emblem off with a very small, flat screw driver with masking tape on it.
Old 02-10-2008 | 05:07 PM
Hyghgynx's Avatar
Originally Posted by BlckdOutTC
gettin rid of the car in about 2 months anyways...
2 questions for you...
1. Why post a thread about removing and re-applying an emblem?
2. Why do the blacked-out emblem when your 'getting rid of the car in a couple of months'?
I just kind of think its a waste to do the project if you're going to get rid of the car. (No offense.)
Old 02-10-2008 | 05:30 PM
BlckdOutTC's Avatar
1. I wasnt sure how to re-apply it when the adhesive is melted
2. I like the way it looks
It was a 10 minute job. Im getting another tC but in stick so everything I've put into my car can be put on the new one (I have all the stock parts) the only things I cant carry over are the tints and the emblem.
Old 02-10-2008 | 05:32 PM
BlckdOutTC's Avatar
Originally Posted by tCeeder
^ the 3M stuff i suggested is the same stuff they use to hold on bumper fascias, lip spoilers and side skirts/front lips. it's incredibly sticky and durable....not to mention waterproof and can withstand extreme heat. superglue can't
Ohhhhh I see. My bad guys. I'll be sure to use that stuff next time
Old 02-11-2008 | 03:06 AM
01msmis's Avatar
yea plus if u ever remove it. 3m will be alot better then superglue. no mark or scratches at all.
Old 02-11-2008 | 03:33 AM
dqlostsoulz's Avatar
Is the tC emblem just held on by 3m tape? Or is it screwed on? And how do you get rid of the access tape left on the car?
Old 02-11-2008 | 04:06 AM
BlckdOutTC's Avatar
i just heated it with a hair drier and used dental floss. just the adhesive tape, no screws
Old 02-11-2008 | 05:17 AM
So if i take it off there will be no trace of anything left behind? It will be smooth as a baby's butt?
Old 02-11-2008 | 05:21 AM
tCeeder's Avatar
^ there will be some sticky adhesive residue which you can remove no problem.
Old 02-11-2008 | 05:37 AM
How ? and is that it?
Old 02-11-2008 | 06:18 AM
Hyghgynx's Avatar
Use Goo Gone to remove the adhesive then use wax bring back the luster.
The "tC" emblem is just held on with the adhesive. The "Scion" emblem has alignment pins on it. So it won't be smooth.
Plus, there's an indention left behind when you remove the "Scion" emblem. That's the part that people have filled in to get a badge-less garnish.
Old 02-11-2008 | 07:03 AM
Thanx...where is a good place to place the tC emblem?
Old 02-12-2008 | 06:05 AM
01msmis's Avatar
yea goo gone work fine. i used that to removed alll the old 3m tape.
Old 02-27-2008 | 10:57 AM
Which one would be better to use to rebadge the tC emblem?
or
Old 02-27-2008 | 12:51 PM
tCeeder's Avatar
the roll in the top picture i what i used, from home depot. but i'd take it back and get the 'exterior' version of that stuff, it will work much better in the heat/cold/rain etc.
Old 02-27-2008 | 02:22 PM
blackonblacktc's Avatar
what would you use to black it out the emblem ?
regular black spray paint ?
Old 02-27-2008 | 02:23 PM
because im also trying to black out the stock grill with the emblem on it as well what would work best?
Old 02-27-2008 | 11:03 PM
Hyghgynx's Avatar
^^Same process as stated above and on the previous page.
Old 02-28-2008 | 03:32 AM
with what though
spray paint ?
Old 02-28-2008 | 03:41 AM
tCeeder's Avatar
like this?
depends what kind of finish you're after. if you want ultra flat black like i did, look for the ultra-flat camoflauge paint in the auto store. if you don't mind a little gloss, you can use any spray paint meant for plastic, it'll say 'for plastics' on it (like krylon).
old pic but you can see it better here..
also good idea to do it with the grill off the car, sand the whole pieces down to and use a primer if you want it to last. i didn't use any clearcoat as i wanted it to be as flat-black as possible.
