Scion tC CLEAR CORNERS (headlights)
Old 11-21-2009, 10:21 AM
  #61
grumpy6489's Avatar
i made my own, only problem i came across is that it doesn't completely light up
grumpy6489 is offline
Old 11-23-2009, 05:57 AM
  #62
user 7208230's Avatar
^that's probably more having the LED than anything else, might need a wider dispersion bulb for that look
user 7208230 is offline
Old 11-23-2009, 06:08 AM
  #63
ibidu1's Avatar
So you are making the corners out of raw material?
ibidu1 is offline
Old 12-03-2009, 09:58 PM
  #64
any updates?
Old 12-03-2009, 10:20 PM
  #65
davedavetC's Avatar
I haven't recieved them yet
davedavetC is offline
Old 12-03-2009, 10:50 PM
  #66
badassco08's Avatar
Originally Posted by Scoobasteve4132
sorry to jack, but been working on it here and there. Getting there!
Hope the next set will be good to go w/o bubbles! Then off to making one w/o texture...
Thoes look great to.
badassco08 is offline
Old 12-04-2009, 02:29 AM
  #67
LEDmod's Avatar
Sorry, didn't get a chance to work on it yet..
Currently, it's very difficult to make the lens with the clips..
But we are working on a new mold to have the clips, so it will be plug and play for the xB2
LEDmod is offline
Old 12-04-2009, 02:30 AM
  #68
LEDmod's Avatar
Is that molded piece or cut to size from home depot diffuser sheet??
You can't make it light up completely, other option you have is adding LED strips...
LEDmod is offline
Old 12-04-2009, 02:32 AM
  #69
LEDmod's Avatar
To get rid of the bubble, you need either vaccume or pressure chamber..
Let me know if you can make them without bubbles, so I that I don't have to make one for the tC
LEDmod is offline
Old 12-04-2009, 02:46 AM
  #70
badassco08's Avatar
i dont think he had a problem with any bubbles in his resin.
I do believe he said he wanted to make the next pair with out the diamond patern to make them completely smooth.
Old 12-05-2009, 06:12 AM
  #71
resin is sketchy...not sure if quality is an issue or what not. But a while back I bought a set of cc's and they yellowed like a SOB, glad that I didn't install them (they broke before I had the chance).
Just throwin' it out there, hope you figured it out or tested to see if discoloration sets in.
Ledmod I thought you were working on tC set? Went xB2 first...? Oh and I'm pretty sure that grumpy used the HD sheets, you can see the gaps on the corners
Old 12-05-2009, 06:50 PM
  #72
LEDmod's Avatar
"Hope the next set will be good to go w/o bubbles! Then off to making one w/o texture..."
You would need the vaccume chamber or some sort to make it without bubble...
So as of now, he hasn't said anything about made them without bubbles..
Depends on the resin, they tends to yellow... not sure what kind of resin he used...
I'm using lexan, I've been testing them under the sun for some time now, about couple of months... it hasn't yellowed yet..
xB2 clear corner is made already...
I'm working tC clear corner request by Dave..
LEDmod is offline
Old 12-06-2009, 05:07 AM
  #73
davedavetC's Avatar
Old 12-08-2009, 05:06 PM
  #74
^^sweet, looking forward to it.
must have been a cheaper resin that yellowed
Old 12-08-2009, 05:42 PM
  #75
beandip007's Avatar
I'm interested for 06 TC
beandip007 is offline
Old 12-10-2009, 07:11 PM
  #76
KAD
carbon_ninja's Avatar
dave pm me , let me know i wanna set 06 housings
carbon_ninja is offline
Old 01-06-2010, 12:52 AM
  #77
what's the good word on these? any updates?
Old 03-08-2010, 01:18 AM
  #78
Scoobasteve4132's Avatar
Lenses are currently being 3d scanned into my computer. Then the diffuser texture will be modified and a new lens will be 3d printed.
Once that's said and done, they'll be ready for molding and production.
Scoobasteve4132 is offline
Old 03-08-2010, 01:20 AM
  #79
KAD
steve or led mod contact me i want a set of 06 tc ones asap
Old 03-08-2010, 02:14 AM
  #80
FlintMica2005's Avatar
yeah scoobesteve let us know when your ready i def want them
FlintMica2005 is offline
Quick Reply: Scion tC CLEAR CORNERS (headlights)
