Splicing taillight wire for accessory lighting
Im going to be adding a rear foglight below the bumper facing the rear and I want to splice the wire that turns on the light when you have the low beams on. Does anyone know which wire I need to spice on the Anzo tails?
best way to find out is to unplug the brake light harness from your tails and turn the lowbeams on then test the harness with a voltage circuit tester.. poke the probe from the circuit tester into each wire connection on the plug one at a time and once you see the circuit tester light up, you've found the wire you need to splice.
Ah! okay thanks Josh!
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
clickclickw00t
02-18-2015 08:57 PM
NewBox06
02-03-2015 12:36 PM
randode
44
06-29-2004 04:19 PM
