TC daily driver to show worthy project
Okay here is the build log of the car project that started 4 years ago. Multiple local hack body shops have screwed me but thats almost all fixed now. The main project is the audio project. Earlier this year my wife bought us an additional SUV so that i can FINALLY pull the scion off the street as a daily driver. She started off as a 2007 Scion Tc Release Series 3.0.
I wont go into all the mods as this is an audio forum. I bought a Ultima yellow top battery of course, with a Tsunami 0 gauge multi amp kit. i proceeded to gut the car recently as you can see.
This is the layer of Dynamat i put on the skin 3 years ago.
I will be putting the panel back on with Stinger Overkill foam sound dampener.
The floor has started to be prepped for the Stinger Carpet Pad
Here is the passenger side with FatMat installed
Wire anchors are being installed under the fatmat as the factory wire guides are to thick to allow the carpet pad to fit.
I purchased a few goodies for the new install.
Bought this from a DIYMA member (AudioControl DQXS)
And these from crutchfield to give me better tweeter imaging until i can figure out the a pillar or kick panel situation.
And this custom full width box from www.supercrewsound.com Well made box and indeed it does fit like a glove
I am keeping my Kenwood Excelon XXV-04s speakers front and for now rear
I am installing the Pioneer PRS-4200 Stage 4 amp and the Kenwood Excelon XXV-03a Amplifier for now until i can swing the Zukki custom amps and ill put the old amps either for sale or in my Rav 4.
I also have an Audio Control Matrix Line Driver this is how i previously had them installed
. My Subwoofer of Choice JL AUdio 12W6v2 SVC. in the old box
This is my old headunit now in the used Rav 4
I will be finishing the FatMat installation slowly as the factory wiring is kind of a pain to move around and resecure. The seat belts need to come out and of course go back in. That part will probably take me a few weeks.
I combined several posts so I can make a cohesive single post.
got a little more work done tonight . got one of the new door panels lined with the Stinger Overkill Foam sound dampener.
and a few more goodies trickle in from amazon
a steering wheel control adapter, a 125' roll of shrink tubing, a 100' roll of primary wire, a bag of 100 zip tie anchors, and a 120' roll of foil tape, and lastly since i was NOT paying the 75.00 crutchfield wanted i paid 42.00 on amazon for the iphone cable to my soon to be head unit
second door to receive stinger overkill
cutting speaker holes
and thanks to my wife this is the suv that allows me to do this project and take the scion off the road as a daily driver
anyway here is this morning update. while waiting for my freezer to arrive i managed to get the drivers side door ready for the speaker wire and speaker
and i see i missed a spor will have to go back and do that
and lastly using foil tape get all the wires nice and secure
getting everything organized for the next phase after the sound dampening...the wiring harness install, ill be putting new battery terminals, new distribution block, new speaker wire, relocating the Audiocontrol Matrix to the glove box and putting the speakers back in the doors to put the door panels back in. Here is the install kit im building slowly
finally got some time today. took out the seat belts. ran into a little issue. the connector is a bit tough. looked it up and you need to remove the black snap keeping the yellow connector in place.
i started to lay the rca cables and the remote wire
i then moved onto the b pillar
i ran the wires for the tweeter. i did not want to remove the dash so i removed the 2 corner bolts just enough to run the wire
the top bolt near the top of the dash
the bottom bolt near the kick panel
the finished run
i ran the wire through the factory grommet from the door
the weather was so nice i used it to install the fat mat in the rear seat
and i even managed to finish the passenger door
and this is why you dont by razor knives in a dollar store lol
the finished run
i am mounting the tweeters on the dash for better imaging. i pulled the dash up just enough to get the wire underneath the lip . It was a PAIN , but turned out good.
i then went about choosing a location for the Audiocontrol Matrix and settled on the glove box as i dont need the space for anything.
Then i had a little time to vibration dampen the trunk
I made the connections for the door speakers and the tweeters. Not bad for a mornings work.
TheTripleC
01-04-2015 06:46 PM
