Trying to lighten my car up a bit...any ideas?
Old 03-01-2008, 07:11 PM
tCmaniak's Avatar
Default Trying to lighten my car up a bit...any ideas?
I know about carbon fiber hoods...
I know about stripping your interior...
I know about getting light rims...
Basically what I would like to do is lighten my car as much as possible without stripping noticeable stuff off the car.
I DONT want it looking like its only made to race...
Any ideas?...
tCmaniak is offline
Old 03-01-2008, 07:15 PM
engifineer's Avatar
Well, you either remove parts or replace with lighter ones... or dont reduce weight. It sounds like you are not a serious race guy, so dont bother in general, just not worth it if you want to keep the stock, street look.
engifineer is offline
Old 03-01-2008, 07:20 PM
Crayola_G's Avatar
lightweight pulley and flywheel? take our ur spare, take out ur seats cf hood and trnk, 2 race seats and fabricate somthing for the back of ur car so it doesnt look like a prison.
Crayola_G is offline
Old 03-01-2008, 07:29 PM
O5_TRD_tC's Avatar
-remove
spare, AC, Windshield washer fluid and reservoir, remove all seats except driver seat, remove all interior panels, remove floormats
Swap:
Hood, Hatch, stock rims for lighter rims
just to name a few.
O5_TRD_tC is offline
Old 03-01-2008, 07:36 PM
ESEMRFOZZ13's Avatar
caron fiber hood, trunk,fenders, doors and roof also maybe carbon fiber lip kit but that adds more weight.
ESEMRFOZZ13 is offline
Old 03-01-2008, 07:40 PM
tCmaniak's Avatar
Well when it comes to a daily driver I apologize for not being a serious "race" guy lol.
tCmaniak is offline
Old 03-01-2008, 07:50 PM
RodC's Avatar
Remove: Roof, doors, hood, trunk, windshield.
RodC is offline
Old 03-01-2008, 07:58 PM
nebster's Avatar
why do you want to make it lighter if you're not planning on doing serious racing?
nebster is offline
Old 03-01-2008, 08:50 PM
Shifty's Avatar
What I've done...
I removed the stock battery and rear mounted a lightweight battery. That's about 30lbs removed from the front and around 15lbs added to the rear.
I have light weight wheels/tires.
Lightweight flywheel and crank pulley.
Beyond that...
Hood/hatch are good ideas but expensive for only about 40-50lbs saved. Unless you like the look also. They do make a CF roof but you will lose sun roof functionality. That removes around 40lbs from the highest point in the car which is very good. Also expensive.
You could get the rear seat brackets redone with aluminum or remove it all together. Racing seats will typically be lighter weight but can be costly also.
New rotors that possibly weight less (slotted/drilled). You'd have to get some measurements to see if you're even saving anything there.
I'm sure there are other options but it's all about how much you're willing to spend and how far you want to take it.
Shifty is offline
Old 03-01-2008, 09:04 PM
tCmaniak's Avatar
I am trying to make it be as quick as possible WITHOUT taking away the practical side. This car will be all motor I am probably not going FI...ESPECIALLY after I found out they are coming out with cams and a stroker kit for this car sometime in 2008. Remember this is my daily driver...
tCmaniak is offline
Old 03-01-2008, 09:17 PM
nebster's Avatar
keep in mind that as a daily driver a stroked out engine with cams is not going to be practical. you'd be much better off going with a low boost turbo setup if you're looking for practicality
nebster is offline
Old 03-01-2008, 10:14 PM
JOEinSD's Avatar
Light[en] up your car? Kinda like this?
JOEinSD is offline
Old 03-01-2008, 10:23 PM
frame's Avatar
this should give you a rough idea on what you need to do
http://www.mlazz.com/projects/14/index.htm
frame is offline
Old 03-01-2008, 10:26 PM
RodC's Avatar
Hardcore.
RodC is offline
Old 03-01-2008, 10:39 PM
tC9o9's Avatar
Originally Posted by RodC
Hardcore.
i lol'd
and currently am rofl
tC9o9 is offline
Old 03-01-2008, 11:16 PM
tCmaniak's Avatar
hahahahaha YES!
tCmaniak is offline
Old 03-02-2008, 02:48 AM
engifineer's Avatar
I never cut you down for not being a serious racer. Lets say you knock off 50 lbs. You will never notice that on the street whatsoever. Unless you are worried about hundredths of seconds on a timed track event, I wouldnt bother with trying to lighten it up since you are trying to keep it practical.
Old 03-02-2008, 09:22 AM
bsptcftw's Avatar
lol.
bsptcftw is offline
Old 03-02-2008, 08:42 PM
tCmaniak's Avatar
I didnt think you were cutting me down at all. I see where your coming from also. but 50 lbs I think might make a little difference. Just by having another person sit in my car I notice a HUGE difference. so lets say if I add an average weight of 115 lbs (my girl) in the car. Just that alone i notice a fricken nuts difference. I dunno thats just me. So I would think ok if I go out and get some lightweight rims, carbon fiber trunk, carbon fiber hatch, PLUS the fact that 99% of all performance parts you buy to replace OEM parts are much lighter than the factory parts, I would think I might save the weight of around an extra person on the car, and THAT I can deal with
tCmaniak is offline
Old 03-02-2008, 09:16 PM
BZinn1's Avatar
A good place to shed 115lbs is lose the girl.............JK............there actually seems to be a few areas that will help.........CF hood........light weight rims............pull the spare..........and jack.......no spare no jack.........racing seats.......lighter battery...........all of these are options that leave it fairly stock looking and you lose a good amount of weight............
BZinn1 is offline
Quick Reply: Trying to lighten my car up a bit...any ideas?
