Uninstalled Kaminari hood pics
Old 03-24-2005 | 01:17 PM
ProPain's Avatar
Default Uninstalled Kaminari hood pics
Whenever I was trying to help my girlfriend make a decision on whether or not to get an aftermarket hood, it seemed like there was a severe lack of GOOD pictures of the hoods. So, basically I'm just throwing these out there for anybody that might be wanting to see the quality of one of these hoods straight out of the box.
I will say that there are some minor imperfections that will require the hood to be primed and sanded on a little, and one edge that our body man said was, "A little too sharp," but overall it looks very good. Also, notice the latch on the hood. It is backed by a large metal plate on the inside which should prevent it from being ripped out by some fluke of aerodynamics.
Old 03-24-2005 | 03:27 PM
Darkness's Avatar
I like that hodd a lot, but not unless it is part of a whole body kit.
Old 03-24-2005 | 03:35 PM
jmiller20874's Avatar
Sweet hood. Wonder how the increased air flow will help something like the WeaponR Short Ram.
Old 03-24-2005 | 04:28 PM
dmikon's Avatar
I really doubt it would increase any flow seeing as how the scoop is facing the rear of the car.
Old 03-24-2005 | 04:43 PM
rolstc's Avatar
air can still flow in there though!!!
Old 03-24-2005 | 04:49 PM
tckurt's Avatar
N.G.S.O.
Its a nice hood just a little pricey.
Old 03-24-2005 | 04:50 PM
VanillaRice's Avatar
Isn't it designed to pull hot air off the engine bay?
Old 03-24-2005 | 05:04 PM
dmikon's Avatar
I don't think any decent amount of air will flow into it. As you are driving, the air is coming in from front to back, that is why hood scoops are typically facing the front.
It might lower the engine bay temperature by like 0.5 degrees simply because it is an additional hole for hot air to come out of.
Old 03-24-2005 | 05:05 PM
That's the whole purpose of the reverse cowl hood on the EVO8, so I'd imagine this would be the case here as well. If it lowered the engine compartment temps then the Secret Weapon would be more efficient, in theory.
Lower air temp = more hp!
Traditionally forward facing hood scoops are for force feeding air onto a top mounted intercooler or forcing air directly into an intake. Reverse cowls pull air out instead of forcing air in.
Old 03-24-2005 | 05:41 PM
hahaitzskippy's Avatar
its actually meant for the radiator. the air comes in from the front and up and out the hood.
thats why you see this style hood on JGTC cars for better cooling of the radiator/IC.
Old 03-24-2005 | 05:45 PM
dmikon's Avatar
I think that unless you race a lot and your engine gets really hot, there is not going to be any difference except for the looks.
Old 03-24-2005 | 08:38 PM
Beantowntc's Avatar
does anyone actually have the full kit installed? any other pics other than the one's on kaminari's site??
Old 03-24-2005 | 09:36 PM
Ditto. Anyone?
Old 03-24-2005 | 10:17 PM
RULETKA
he has the whole kit installed except the hood i believe. PM him or something
Old 03-24-2005 | 10:46 PM
CHICO's Avatar
That hood is perfect for turbo applications. I would really love to see the full kam kit on a white Tc. or any other Tc for that matter.
Old 03-25-2005 | 03:00 AM
jrv2000's Avatar
if it rains a lot will water run into the engine? From the pictures, it looks like it would drip right in
Old 03-25-2005 | 03:47 PM
The only way water could get into the engine is through the intake. As long as no water enters your intake, your fine. If not, you'd have EVO's blowing up left and right.
Old 03-25-2005 | 05:52 PM
jrv2000's Avatar
Sorry, I should clarify what I meant. What I was trying to ask is if water can run into the engine compartment, I didnt mean inside the engine itself. Still though if the water still drips into the engine compartment it couldnt be a good thing. I would think that after a while you would start having problems with electrical systems and rust. Could anyone clarify?
Old 03-25-2005 | 06:13 PM
Oh ok, well in that case, do you drive your car in the rain? Your engine bay gets wet regardless of what vents are on your hood, rust shouldn't be a problem especially since most of what's under our hood is aluminum or plastic. The electrical components were designed to handle this stuff, so unless the front of your car is completely submerged, they won't be affected either.
Old 03-25-2005 | 06:19 PM
dredge38's Avatar
i want that type of hood for my xb
