vht night shade
Who said its flat?
You shouldn't buy paint that already has clear coat in it.
So VHT Night Shades alone is flat but it should be applied as well as clear coat, wax, polish, etc. to get the nice clean shine you want.
Like them? They're for sale right now lol, seriously they are in the classified section.
It isn't really all about the clear coat. I used Duplicolor Acrylic Lacquer but there is a better kind out, I couldn't find it in the local auto stores though. It is UPOL #1 clear, i've never used it personally but i've heard it is better than Duplicolor, can be handled in 2 to 3 hours as opposed to Duplicolor which states basically overnight. You should do them in an area that has low humidity.
The important thing is getting your layers as even as possible, wet sanding A LOT and giving the layers time to dry.
Wet sanding just makes sure your coats are clean and smooth, not a lot of orange peel. Put it this way, the more wet sanding you do the easier it will be to obtain the shine. If you don't wet sand enough no matter how much clear coat, wax and polish you use they will come out like crap and dull.
ok thanks for the tip. wat kind of polish do you sugget that i use? i kno how to detail cars and stuff like a beast, but i dont kno nothin about painting and getttin the shine out of a dull surface.
yep UPOL Clear is the best that i have used and i have done about 30 different kinds of tails...if u dont clear them it will stay flat but clear then high speed buff them and they will look like ecko04s
