VRD Fogs installed and leaking!
Old 07-31-2008, 02:57 AM
carguyphil's Avatar
Default VRD Fogs installed and leaking!
I put my VRD's in about two weeks ago, and the left one has filled with water, and is turning yellow...
Ill get a picture tomorrow...
How do you seal these things? Ive never heard of them leaking before now either...
carguyphil is offline
Old 07-31-2008, 03:01 AM
O5_TRD_tC's Avatar
did u put on the rubber boot properly?
O5_TRD_tC is offline
Old 07-31-2008, 03:08 AM
carguyphil's Avatar
Hmmmm I got them used, but never installed.
VRD refused to send me even a pdf of the instructions. There useless.
Im not sure if I got the rubber boot....
Old 07-31-2008, 03:21 AM
tophers_tC's Avatar
im sure you can google the PDF instructions.
as for the leaks, yeah check the rubber seal cap. If you didn't get one i'm sure there's a way to ghetto rig it.
tophers_tC is offline
Old 07-31-2008, 03:35 AM
carguyphil's Avatar
Is that the rubber seal that goes around the actual bulb? Because they were installed correctly.
I didnt know if it was some sort of rubber cap that fits between the glass and the actual metal of the light housing....
Old 07-31-2008, 03:37 AM
TwztedtC's Avatar
https://www.scionlife.com/forums/vie...d+installation
Here is this I am not sure if the pictures werent showing up for me or were taken down
TwztedtC is offline
Old 07-31-2008, 08:57 PM
carguyphil's Avatar
I saw that haha, the pictures havent work for a couple months though....thanks anyway haha
Old 08-07-2008, 02:57 AM
carguyphil's Avatar
Ok so here is the picture of what a VRD fog looks like.
Remember, I have permanently cut my lip to install this product, which now looks like crap.
Old 08-07-2008, 02:58 AM
carguyphil's Avatar
Bump
Old 08-07-2008, 05:49 AM
andrewStC's Avatar
that sucks
andrewStC is offline
Old 08-07-2008, 06:19 AM
MN Scions
Jdub86's Avatar
If you can't fix it you are going to have to buy new ones.
Jdub86 is offline
Old 08-07-2008, 06:27 AM
O5_TRD_tC's Avatar
holy crap!!! you better disconnect the battery and then get all that water out.
Old 08-07-2008, 06:29 AM
tCtCtC's Avatar
DEF. check everything!
tCtCtC is offline
Old 08-07-2008, 06:52 AM
miketf1's Avatar
get a new set. these are basically destroyed... the yellowing of the chrome reflector cant be removed unless youre willing to take apart the light and that might not even cure it. harsh it may sound but this set is toast...
miketf1 is offline
Old 08-07-2008, 03:24 PM
ichibansf's Avatar
Dang, that's gonna be a PITA to get out with the lip kit. You can try baking it open and cleaning it, but I doubt it will be the same. Try some meguiar's mag polish to restore the shine. New set from apt.auto on ebay is still $110.
ichibansf is offline
Old 08-07-2008, 03:30 PM
zer0myst's Avatar
damn@the pic
just installed my vrds on tuesday. I took my time and made sure those rubber boots were locked down tight.
guess i won't know until it rains or i hit a puddle
zer0myst is offline
Old 08-07-2008, 04:44 PM
TwztedtC's Avatar
I just notice mine had a little moisture in them but there wasnt water in it like that.
TwztedtC is offline
Old 08-07-2008, 05:21 PM
thekevin's Avatar
put an overlay on it.
thekevin is offline
Old 08-07-2008, 05:27 PM
ichibansf's Avatar
Pimp your ride... add goldfish.
Old 08-07-2008, 06:08 PM
MN Scions
Jdub86's Avatar
When you buy a new set you could run some silicone around it to help seal it as well.
Jdub86 is offline
Quick Reply: VRD Fogs installed and leaking!
