06 tc shut off on the way home
coming home from work today the tc shut off...wouldn't start at all..when i got it home i turned to key on to see if i can hear the fuel pump and it didn't turn on.. is there anything alse i should check before i start to change the pump...tc's got 157,000 miles on it and 5 spd...any info will help..
Always check fuses. Will it crank?if it cranks and wont start try n have a friend spray starter fluid up the intake into the throttle body and see if it will start. And if it does then its a bad fuse or pump.
It died while driving? First thing to check is the Alternator, then the battery. Those are the most common and simple causes of a car dying during operation. Don't just jump to a pump. Do the lights or ANYTHING come on?
i just checked the fuses and found the ignition fuse was burnt out..gonna start checking for a short ...why would it burn out while driving? i did change the air/fuel ratio sensor about a week ago.had code 420 before i change it and codes 0031 & 2238 after...
Fuses sometimes blow just from being old/fatigued. Put a new one in and see how long it lasts. If it blows right away you have a short. If it doesn't blow you are probably ok, just keep a few spares in the car in case.
Fuses only blow when there is current present. The ignition fuse always has current when you are driving (ignition switch on).
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
drgonzo92
14
04-24-2019 07:27 PM
BlingSlade
09-05-2015 08:52 AM
