07 MAF Sensor Removal?
Has anyone encountered problems removing their MAF sensors from their 07s? My friend says that it's only held in place by one screw and its in there pretty tight.. he doesn't wanna crank on that screw before making sure that it's safe to do so (his intake didn't come with instructions) and all the guides here are only for the 05-06's..
help!
help!
The 05 06 guide will work and the MAF is held in by 2 screws. Undo them but make sure you are turning the right way. The old guides will be identical to the new one with the exception of how the MAF looks. You will be fine just take your time.
Limp mode will basically cause your car to choke out if you go past 3k RPMs with lots of bogging along the way. it's happened to my other friend's tC after his MAF decided to take a dump on him.
not only will it do that but it should throw a check engine light. i tried doing that w/ another car... yeah i was like crap never doing that again. anyways it basically tells the comp how much air is going in so that it can keep the right air fuel ratio.
Bakoscion46x
01-19-2015 03:39 AM
cid_mcdp
01-05-2015 03:45 PM
kdanie
47
02-07-2006 06:46 AM
