2.4 liter differences
"The 2AZ-FE is a 2.4 L (2362 cc)Bore is 88.5 mm and stroke is 96 mm. Output is 157 hp (117 kW) at 5600 RPM with 162 ft·lbf (220 N·m) of torque at 4000 RPM. The 2AZ-FE also has a one-piece cast camshaft and cast aluminum intake manifold.
A different version found in the Toyota RAV4 produces 165 hp (123 kW) at 4000 RPM and 224 ft·lbf (304 N·m) of torque at 4000 RPM."
where is the torque coming from? Is it a smaller bore but stroked motor in the Rav4?
I read the tC's 2AZ has a different intake manifold because of space issues.
The wikipedia description says the 2AZ is made in Kentucky, but isnt the tC's 2AZ made in Japan (along with the rest of the car)? Maybe that accounts for something lol.
- No N/A four-banger that i know of can put out 224 ft-lbs. Torque is a function of displacement .
We've got one of the torquiest n/a 4-bangers out there, actually very close to some small v6's.... (the hyundai 2.7L, and vw 12v VR6 for example.)
We can also compare the tC version with that used in the Camry. Previous generation Camry internals were supposedly the same, but people found out those bearings don't fit the tC engine. The new Camry engine is again supposed to be the same, yet has 9.8:1 compression, compared tot he tC's 9.6:1. It seems like Toyota does something a bit different to the engine for each car it's used in, such that all "2AZ-FE" are not the same, even internally.
Originally Posted by Lip
like..the 2az-fse etc. just surfing and searching
The previous Rav4 had a 2.0L I4 diesel option code name 1AZ-FSE. Don't know the specs for that one. The current Rav doesn't have a diesel option for Japan. Diesel version is certain for Europe.
http://toyota.jp/rav4/dynamism/engin/index.html
ahhh....let me input...yes it is totally normal for a diesel motor to put out enormous amounts of torque compared to horsepower..because the ignition system is vastly different than that of a regual fuel injected vehicle....look for example in the VW golf TDI and the various mercedes diesels, diesles also get killer gas mileage......as far as the engine code goes..... 2az would be the engine family ( ex: 4a, 3s, 2zz) f = head machined for fuel mileage, e = electronic fuel injection
for an example a 91 celica came with 3 motors ill use two for this one
3s-fe in the GT
3s-gte in the GT4(alltrac)
we can also use the ever popular 2jz-gte(turbo supra)
AND 4A-GE(85-87corolla gt-s)
notice the engine code at the beginning and yeah i guess i was right
f= head machined for fuel mileage
g = high flow head
t = turbo
hope this makes things easier for you when looking into the toyota engine family
3s-fe in the GT
g = high flow head
t = turbo
I understand the basic Toyota engine code and by the way it’s "AZ" as the family. The number in the front of the engine code is for the stroke length or otherwise the total displacement (i.e. 2az is 2.4L while 1az is 2.0L). Anyways according to Wikipedia the 1az-fse is a direct fuel injection which is also gasoline. Also I do not think there is a 2az-fse in the states anyways (only Japan might have one). The differences in power between the rav4 2az and the tC is the size/shape of the intake manifold and exhaust manifold/exhaust. Also there might be slight differences in the internals but that is something someone will have to find out by actually comparing the 2.
This is tC specific specs...as far as I know by my experience it is identical engine specs to the camry. I've always found this info useful, so hopefully it will help here as well.
AZ-FE
ENGINE SPECIFICATIONS
Type: I4, 2.4L, chain-driven DOHC, four-valve, open deck,
aluminum block and head
Displacement: 2362cc (144 cid)
Bore x stroke: 88.5 x 96mm (3.48 x 3.78 in.)
Horsepower: 160 hp @ 5,700 rpm
Torque: 163 ft.-lbs. @ 4,000 rpm
Compression ratio: 9.6:1
Emission control: EVAP
Fuel system: MPFI
Fuel pressure: 44-50 psi @ idle, 21 psi hold
Fuel injectors: 11.6-12.4 ohms
Oil pressure: 4.3psi @ idle, 36-78 psi @ 3,000 rpm
Valve clearance: Intake, 0.008-0.011 in. (0.19-0.29mm); Exhaust,
0.012-0.016 in. (0.30-0.40mm). See Technical Notes.
Spark plug gap: 0.039-0.043 in. (1.0-1.1mm)
Firing order: 1-3-4-2
Ignition timing: 5°-15° BTDC @ idle
Base idle speed: Manual, 650-750 rpm; Automatic, 610-710 rpm
ELECTRICAL SYSTEM
Battery: 12V
Alternator: See Technical Notes.
Ignition: Direct
CAPACITIES
Oil/filter change: 4.0 qt. (3.8L)
Automatic trans: 3.7 qt. (3.5L)
Manual trans: 2.6 qt. (2.5L)
Fuel tank: 14.5 gal. (57L)
Cooling system: 7.2 qt. (6.8L)
Refrigerant: 14.1 ??1.1 oz. (400 ??30g)
Compressor: 4.7 ??0.5 oz. (140 ??15cc)
LUBRICANTS
Brake fluid: DOT 3
Engine oil: API SL, SAE 5W-30
Automatic trans oil: Toyota ATF Type T-IV
Manual trans oil: API GL-4 or -5, SAE 75W-90
Power steering: Dexron III
Refrigerant: R134a
Compressor: PAG ND-OIL 8
MAINTENANCE
REQUIREMENTS
Oil and filter: 5,000 miles
Spark plugs: 30,000 miles
CHASSIS SPECIFICATIONS
Drivetrain: FWD, five-speed manual or electronic four-speed
overdrive automatic transmission
Brake system: Disc/disc with four-channel ABS
WS sensors: Front, 1,400-1,800 ohms; Rear, 1,000-1,300 ohms
Front disc thickness: 0.906 in. (23mm) minimum
Rear disc thickness: 0.295 in. (7.5mm) minimum
SUSPENSION SYSTEM
Front: MacPherson struts, A-arms, stabilizer bar
Rear: Lower A-arms, one upper link, coil springs, tube shocks
Lug nut torque: 76 ft.-lbs. (103 Nm)
Axle nut torque: 159 ft.-lbs. (216Nm)
FRONT ALIGNMENT
SPECIFICATIONS
Toe: 0° ??12’
Camber: -0°31’ ??45’
Caster: 3°02’ ??45’
SAI: 12°31’ ??45’
AZ-FE
Fuel system: MPFI
ELECTRICAL SYSTEM
Battery: 12V
Ignition: Direct
CAPACITIES
LUBRICANTS
Brake fluid: DOT 3
Refrigerant: R134a
MAINTENANCE
REQUIREMENTS
SUSPENSION SYSTEM
FRONT ALIGNMENT
SPECIFICATIONS
Toe: 0° ??12’
Caster: 3°02’ ??45’
SAI: 12°31’ ??45’
now that I look hard a second time...I think the spark plug spec is wrong. I'm pretty sure they are factory platinums...usually platinums are like 100k plugs. Either way, 50-60k is pretty realistic.
