200 hp?
200 hp?
is there any way of me to get 200hp or close to 200hp without breaking the warranty on the car. and without buying the trd supercharger.
and suggestions.
and what would be the most i could get without breaking the warranty.
and in an auto.
and suggestions.
and in an auto.
Any mod will void at least parts of your warranty, sorry.
You get a header and blow a gasket and it wont cover it. You get a header and your shocks blow out, you're still covered by warranty. Toyota has to prove the aftermarket item caused the problem for it to void your warranty.
It can be said that anything to get your close to 200 hp will destroy your engine-related warranty. If you go forced induction, well that's an immediate killer. If you go N/A, it'll take large amounts of tuning and work with the internals that'll kill Toyota's desire to back you up.
Hmm, 200whp? Maybe full header-back exhaust, good intake, maybe an agressive cam setup and a really good tune and you're getting close. Only problem with trying to get more power N/A makes things a little more of a terror in the daily drivability dept. <-But that depends on how much of an enthusiast you are. Some people daily drive their 10 second cars all the time here
In the V6 F-body world, we have some pure N/A cars running 12.5's in the 1/4, somewhere in the 250-300whp range and they are just about the max of their capability without a stroker kit. That's a whole other monkey wrench in the works.
Just to note, the cars running the higher hp in the v6 community are full heads/intake/cam/exhaust cars on agressive tunes.
OP: Stop making these stupid threads. It's been discussed before. Learn to search.
search...theres a few threads on this topic.. but theres no way of getting to 200 without breaking open the head with a head swap or the block and adding hich compression pistons. you will need to do both to get to 200 NA.
First, cams, intake (worthless), header back (not near what they advertise) etc wont get you close. It will take internals (higher compression) and a lot of other work to get it done, including most likely raising the redline (Again, internals). I am not saying an NA build would not be fun, but people think bolt ons are like magic.. cause they believe too many online dynos and advertisements.
Second, I swear that there should be a feature that suspends you for mentioning void and warranty in the same sentance. This has been discussed a billion times.
Finally, and most importantly, you should search first.. this has been beaten to death.
Ah, didn't know there aren't any cams available for these cars yet.
Guessing w/ the differing technology of the VVT-i or whatever compared to a regular pushrod engine, there are other things you have to take into consideration when the cam profile changes at the higher rpms.
In the domestic world, exhaust and intake are just minor mods that can support the larger stuff in regard to heads work and internals modification like cams and such. I know the OHC world is quite different in some aspects. I'm still learning, but I do it quickly
EDIT: Woops, I just noticed a flaw in my thoughts on the VVT-i system. Was thinking Vtec system Realized the error, so there aren't differing cam profiles it's just an advanced timing on the intake cam on a variable pulley.
Some companies have looked at building cams for the tC. The comments I remember hearing is that it would be nearly pointless due to the small amount of gain they could squeeze out, especially considering the amount of work to get them right on our setup.
It's pretty much the all or none approach with this engine eh? Oh well, I'm not getting this car for absolute earth shattering performance, but it's on par with my bird, has a reasonable sticker price and has a warranty
its almost like toyota knew what they were doing when they designed the engine! Look at the intake for example, what a 1hp increase for an aftermarket one thats ten times louder and lets more dirt in. Toyota did a good job keeping it freeflowing. Same goes for the cams valves, head etc etc. If you want a substantial power increase you have to find where they had to cut corners. Which mean sacrifice. More noise more maintnence etc etc. Raise th compresion and increase displacement. Require hier octain gas, retune with an emanage. Larger valves sacrificing low end torque etc etc. Its is very possible to make 200 hp na, buuuuuuuuuut. You will void the warranty with the first part you put on.
Originally Posted by engifineer
...people think bolt ons are like magic.. cause they believe too many online dynos and advertisements.
Wasn't it P.T. Barnum who said "There's a sucker born every minute"?
