2011 tC 6 speed Tranny Swap Discussion
Old 08-08-2010 | 12:42 AM
  #81
Hix's Avatar
Hix
Originally Posted by rangerryda
I've got a strong feeling it's do-able but that's just a hunch. Hell the guy on here put a 3.3L in his and kept the stock trans with almost no issues. Just fabbed up some mounts from what he said. Looked OEM too
That guys car was insane. I might try to swap something into mine since my transmission is blown, but I doubt it will be this trans since the new tC and old tC have nothing in common.
Old 08-08-2010 | 07:55 AM
  #82
divisii's Avatar
I know ppl asked if it's worth it to swap, but I didn't notice have specifications been posted yet... 'cause theyr'e up on toyotapressroom.
http://pressroom.toyota.com/pr/tms/s...pdf?ncid=12047
Old 08-08-2010 | 01:56 PM
  #83
Carlanga's Avatar
well, they are virtually the same for 1st and second, 3rd slighty higher and 4th higher, so on so on. I'm not sure if that much of a difference between 5th (current) 6th (new one) is enough to drop rpms. Heck 1/4 mile times might suck even more, 1st and sec about the same, but 3rd might. Just like the new STI and WRX.
For the lazy ones ;-P
Current
1st 3.538
2nd 2.045
3rd 1.333
4th 0.972
5th 0.775
New
1st 3.538
2nd 2.047
3rd 1.375
4th 1.025
5th 0.875
6th 0.733
Old 08-08-2010 | 02:11 PM
  #84
OPPOSITE-LOCK's Avatar
Damn. Why does toyota want these engines to always be turning so many rpms on the highway? Grr.
Old 08-09-2010 | 12:23 PM
  #85
BlackKnight's Avatar
Music City Scions
Wow! Some people should step away from cars and tools. If cars cant run right cause you changed gears or final drives then how does your car still drive after changing gears in manual transmissions and I'm sorry but rangerryda knows what he is talking about. Listen to him!
Old 08-09-2010 | 06:18 PM
  #86
tokenride86's Avatar
notice how you dont need to downshift to pass people?
Old 08-09-2010 | 09:32 PM
  #87
True, but at what [eventual] cost?
Old 08-10-2010 | 09:38 AM
  #88
gotta pay to play lol
Old 08-10-2010 | 02:41 PM
  #89
bdis3's Avatar
World racing could probably tell us if it fit. They have a new tC in their shop.
you can see it in the vid around the 1:18 mark. its silver. then they talk about it later in the video.
http://www.youtube.com/watch?v=U7loe0wj2to
Old 08-10-2010 | 05:39 PM
  #90
rob told me it wouldnt fit. but i wanna see someone try
Old 08-27-2010 | 02:40 AM
  #91
SicKtC18's Avatar
i haven't seen a new tc yet has it came out?
Old 08-27-2010 | 06:15 PM
  #92
serith's Avatar
Not only do they not want the cars to last as long as they could, they definitely can't have a $17k coupe achieving 40mpg--think of the poor Prius sales!
How sweet would it be if the rpm's dropped down under 2k when you shifted into 5th at 65mph. Sigh.
Old 09-03-2010 | 07:15 AM
  #93
TJKASS's Avatar
For all you people wanting super low cruising speeds, swap in a camry box from an 03-07 2az camry, itll get you to ~78 before 3k rpm, or since toyota has followed their tride and true method of "take whats in the camry and shorten the ratios" with the new tc as well, try swapping in the 2ar camry six speed, literally these ratios are just pitiful, and i promise youll be shifting back out of sixth all the time but...
3.538
2.047
1.375
.975
.744
.659
and all with a FD of 4.058
so on the 1st gens stock 17s a whopping 82mph before 3k (on larger wheels this will be higher), be ware though, that is a very very long setup for an engine with as little power as ours so you best enjoy a lot of shifting.
honestly I feel a franken-box is still the best way to go, I love keeping the stock E350 final drive but getting a .73 fifth gear, still goes like before but does 75 at about 400 rpm less
Old 09-08-2010 | 12:17 AM
  #94
boosted239's Avatar
I think its possible! im gonna go for it later on, im also tired of high rpm highway driving!
Old 09-09-2010 | 05:45 AM
  #95
s_rhabb's Avatar
Team Scionara
Default 2011 tranny swap
Originally Posted by cburglb34
you guys are all complete idiots stop bashing... if u knew anything of the new 2.5 and or have seen it in person the block looks idetical to that of a 2az, the 2ar(2.5) is just a stroked out 2az with more compression, diffe3rent head, and other minor stuff,
THIS MEANS what ever tranny bolts to that black will bolt up to ours...now the only issue would be to get that tranny motor mount made to fit our car..
and for those who seek to drop the new 2.5 in there wait till the new tc actully comes and see if the motor mounts need messing with, after looking at a camry the motor mounts are different but things could change 4 the tc
People are forgetting all about what to do with the ECU.
Old 09-09-2010 | 05:55 AM
  #96
s_rhabb's Avatar
Team Scionara
140 in a tc? I bet that was a little twitchy!
I had on 05 back when the tc first hit the market and I was burying the needle through west Virginia no problem.
Old 09-10-2010 | 05:37 AM
  #97
I don't think so. There's tons of posts in here about whether or not a new ecu is needed. I'm in the "keep the stock" ecu camp.
Old 10-08-2010 | 01:53 AM
  #98
gwtc's Avatar
Here's a pic I snapped today:
It does look a bit different, so like Rob said it will not work, but I'm sure someone will try anyways.
Old 02-15-2011 | 10:15 PM
  #99
r2d2michael's Avatar
talked to many shops and gone over what trannys come with what motors and the new 6 speed U760E AUTO will bolt to the 2ar-fe AND 2az-fe and visa versa. what i want to know is what is needed to bolt the 2ar-fe into my 09 xb. new motor mounts wire harnes ecu?
Fisqual
09-22-2015 05:51 AM
Dmmcclair
08-13-2015 07:14 PM
kleecker
04-04-2015 02:37 PM
VitaminE
03-24-2015 03:36 PM
churrosurf
01-30-2015 01:12 PM
Quick Reply: 2011 tC 6 speed Tranny Swap Discussion
