2az-motor qustuons
2az-motor qustuons
im trying to do a motor build and i wanted to know is all the 2az's the same i mean if i wanted to sawp a camery or a highlander head or block would it match up the same as the Tc 2az's and what about the intake manifold im just tryin to find out wats different....if you know any thing please help
Only a guess - and with a little bit of logic behind it...
The motor should be the same as long as the engine code (2AZ-FE) is the same. Usually the only differences between cars would be electronics and transmissions.
Originally Posted by Wikipedia
Output for the 2007 Toyota Camry is 158 hp (118 kW) and 161 lft·lbf of torque. There is also a version of the 2AZ-FE engine with 161 hp (120 kW) and 163 ft·lbf (221 N·m) of torque made in Japan for the Scion tC. A 166 hp (124 kW) version is in the 2006 and newer Rav4. This engine is available for the Toyota Matrix and Pontiac Vibe twins as well as the Toyota Corolla beginning in the 2009 model year.
You can use the head and block from any 2AZ for your tC no matter what it is out of. But keep in mind the tC intake mani is different because it uses a different Throttle Body and in th 07 up tC engines they bumped the compression up a bit and added oil squirters to the bottom of the cylinders for added oiling. So all in all you can use any 2AZ with no problems just not the Intake.
the cars have diferent goals different smog stuff different cats different exhaust this is why
i was additionally under the impression that the block is the same, but theres disparity in the intakes and exhaust. And yes the tCs have a higher compression ratio in the 07s and 08s. the new ones are at 9.8:1 and i believe the 05s and 06s are at like 9.6:1
slight differances in intake manifolds from what I have seen and tC has its own throttle body that from what I can find no one else has the same for their 2.4s.
soem Yaris owners swap out xD throttle bodies for their 1.5s for the bigger body.
There are a few engine builders that found out the internals are different. The bearings and a few other parts were found to be different after a company tore down the engine to rebuild it they bought Camry parts from a 2AZ-FE engine and the parts did not fit.
