2AZFE Fuel Rail //Dezod Motorsports//
The Dezod Motorsports Fuel Rail is designed to allow fueling to the engine beyond the capacity of the factory fuel rail. Our CNC 6061 Billet Aluminum Fuel Rail features a large -8 bore (.6875”) that can be used for any street or race application. The large internal bore acts like a reservoir with larger injectors keeping more fuel on tap, and works perfectly with stock sized injectors as well. The fuel rails are also anodized to a Type II MIL-A-8625 military spec, which makes this rail methanol and E85 compatible. This versatile rail is ideal for any application.
The Dezod Fuel Rail also includes OEM quality delrin fuel rail spacers, which no other 2AZ fuel rail manufacturer includes other than OEM Toyota. These high-temp plastic spacers help prevent heat transfer from the cylinder head to the fuel in the rail. Having less heat in the fuel rail itself is optimal for helping to prevent detonation and fuel vaporization, which is very important on any vehicle.
*No additional parts required for installation
*Manufactured and assembled in the USA
*Allows use of stock fuel pressure regulator
*Bossed O-ring fittings for a leak-less seal
* Military Spec Type II Anodizing (MIL-A-8625) makes the rail methanol &E85 compatible
Can be used N/A, turbo or S/C!!
http://www.dezod.com/pd_dezod_motorsports_2azfe.cfm
If you choose return line is the return fitting on the end of the rail or in the middle like PTuning? If it is on the end can you tell me what thread type it is? I am intrested on putting a push barb fitting on there.
steeze69
05-24-2021 02:57 AM
2az, 2azfe, cnc, compatible, dezod, fe, fuel, head, motorsports, rail, scion, tc, transmissions, west
