After the Header... Custom S pipe...
I was planning on getting a new S pipe
probably Bent by Meneieke
What size pipe would you reccomend...
i think the ZPI has a 2.5 " pipe
i dont know if im correct..
but what size would you reccomend
should i go above what ZPI has.... say 2.75 or even 3?...
keep in mind this will be along
w/ a stock intake for now (eventually getting Wepon R + Cold Air Box)
w/ a stock Exhaust
and AW Header
..ty for the info..
have a nic eday
PS... where do i hav to put the o2 Sim... cuz if have to drill it into the S pipe
ill hav the s pipe installe first...
w/ a stock Exhaust
and AW Header
..ty for the info..
have a nic eday
Yeah, as souljah said, mandrel bending is key.
As far as I know meineke doesn't mandrel bend. You'd probably lose performance by having an "uneven" bend which would creat turbulance and unneccessary back pressure.
i see you are from NJ. you might want to try calling turbo trix(in edison) www.turbotrix.com (Phone732)572-6866 Fax732)572-6733) or precision tuning(in brick) http://www.precisiontuning.com/ and seeing what they will charge to built you a custom s-pipe. precision specializes in subarus but i know they do top notch work. not sure if they will work on a scion but it's worth a shot. turbotrix also does top notch work. i would highly recomend both shops.
Originally Posted by effin_sciontc
Turbo trix will work on Scions i already spoke to them bout putting my turbo kit on
SloTC1
08-16-2018 02:45 PM
