ALPHAWERK 60mm throttle body....
Old 11-20-2005, 11:03 PM
insanetc's Avatar
Default ALPHAWERK 60mm throttle body....
wuts up everybody....so i have alphawerk header,injen cai,and driver fx drag race exhaust and i want to buy the aplhawerk 60mm throttle body i was just wondering if anyone has installed or knows any gains or any info on it.....thanks everyone for your help...[/i]
insanetc is offline
Old 11-20-2005, 11:14 PM
taek's Avatar
never heard of it
-taek
taek is offline
Whocares05050's Avatar
I dont of anyone to buy it yet, but the gains are very minimul. If all you have done is I/H/E then i would wait for a couple more mods before adding this. This TB Should only net about 3-4 hp with your current mods. Next I Would probably get your head P&P or order the ZPI head and cobine all that with an emanage, and then try and work on your ignition, then the TB. If you do get it now, hopefully youll keep all of us informed on to what the power gains feel like and how hard the install was.
Whocares05050 is offline
Old 11-20-2005, 11:22 PM
insanetc's Avatar
this might sound stupid but where can i find the zpi head i tried going on zpi.com but it didnt work do you know the website..
insanetc is offline
Old 11-20-2005, 11:27 PM
www.zpiracing.net
www.thescionstore.com
Old 11-20-2005, 11:45 PM
toyota_scion_tc's Avatar
Default Re: ALPHAWERK 60mm throttle body....
You should notice some nice gains across the entire power band. It may only be 5hp or tq but it will definately be there. Like Whocares05050 said it is definately a combination mod and would definately be noticed with a p&p head.
toyota_scion_tc is offline
Old 11-20-2005, 11:47 PM
DuMa's Avatar
the throttle body add-on was intended for FI people. i doubt u would see much gains with an IHE setup
DuMa is offline
Old 11-20-2005, 11:54 PM
I had a civic that I had a i/h/e on then I bolted on a tb and it made a hugh diffrence. This is a bigger engine it will definately help. The Integra type r comes with 62 or 65 stock I can't remember. The stock civics have 55mm. I put a 62mm on the civic I had and I could chirp third after it.
Old 11-21-2005, 12:09 AM
TurboCustomz's Avatar
Where are the dyno results that shows increases for the P&P head?
A larger throttle body will definatly be a better mod for a FI setup. On a stock setup, you can actually lose HP if you go to big. Its possible to increase flow, and lose velocity creating a HP loss.
Charles
TurboCustomz is offline
Old 11-21-2005, 12:33 AM
Charles
I dont know were the dyno for it is, but this is from ZPI's website:
" The ZPIracing stage 1 cylinder head is for the serious enthusiast. With larger port matched intake manifold ports this head provide a 38% increase in flow over the stock head. This package has netted 21whp with the stock air filter in stock cat back in place. This system will make the car run overly rich and more power can be found when used in conjunction with a piggyback fuel controller. "
http://www.zeropointindustries.net/s...products_id=29
Old 11-21-2005, 12:42 AM
Charles
Thanks. I'd like to see the dyno and flow sheets. I searched but didn't find them anywhere??? Anyone???
Old 11-21-2005, 01:09 AM
Are you laughing because you you do not believe ZPI or what?
Old 11-21-2005, 01:11 AM
Mostly, but Im sure the dyno graphs and the flow sheets that they got these numbers from would shut me up. Of course, thats only if they exhist.
Old 11-21-2005, 01:48 AM
Diluvium's Avatar
check
http://sciontcperformance.com/
or
http://suzukird1.netfirms.com/scion-..._session_1.php
their I/H/E with TB claims 23 WHP and 19 ft-lb of Torque all together. but with TB added it only gained 1hp and 1tq...
im pretty sure you will throw a CEL with that TB too... so i think you would be wasting your money on that crap anyay...unless you get FI...
Diluvium is offline
Old 11-21-2005, 01:54 AM
Originally Posted by Diluvium
check
or
...Didnt MMW's Header clam 24 hp by itself
Old 11-21-2005, 02:42 AM
Souljah347's Avatar
Charles
maybe i'm thinking of someone else but don't you work for ZPI? couldn't you just look for them?
Souljah347 is offline
Old 11-21-2005, 02:45 AM
No, I WORKED for ZPI. Unfortunatly for some, I am no longer with the company.
Charles
^ Who are you asking?
Old 11-21-2005, 02:54 AM
Souljah347's Avatar
Charles
sorry to hear that man. i spoke with you on the phone once, you were quite helpfull
Old 11-21-2005, 03:00 AM
Glad I could have helped. If you were the guy I got frustrated with, please accept my late appology. If not, disregaurd.
Don't be sorry, Im not.
Charles
Quick Reply: ALPHAWERK 60mm throttle body....
