Alright need helping convincing my dad for me to get a CAI
Old 05-28-2008, 01:44 AM
benmlb12935's Avatar
Default Alright need helping convincing my dad for me to get a CAI
Alright, i been wanting to get injen CAI for awhile now, and my dad has been skeptical because of the warranty issue
I explain everything about the Magnuson-Moss act, and whatever, and he gets the whole sha-bang.
Anywho, he thinks that the CAI can cause problems for a ton of things under the hood and that when those things break its the CAI's fault
So my question is, how many problems can CAI cause, and how many things is it related to that it can void the warranty on those parts.
benmlb12935 is offline
Old 05-28-2008, 01:46 AM
scionkidd's Avatar
NONE!!!
scionkidd is offline
Old 05-28-2008, 01:49 AM
ScionERA
lil_will's Avatar
Hydrolock.
lil_will is offline
Old 05-28-2008, 01:56 AM
BlckdOutTC's Avatar
Originally Posted by lil_will
Hydrolock.
only if you drive in 2 feet of water with an unprotected cone filter for quite a while
BlckdOutTC is offline
Old 05-28-2008, 02:04 AM
Alright just to be 100% safe, wheres the best place i can purchase a BPV for the injen intake and would the hydroshield help also?
I appreciate this guys.
Old 05-28-2008, 02:06 AM
BlckdOutTC's Avatar
not too sure about the bpv but is the hydroshield the bag that goes aorund the filter? i think the bpv is good by itself
Old 05-28-2008, 02:08 AM
yeah the hydroshield looks like a bag around the filter.
But the bpv would pretty much do it for me i would think.
Old 05-28-2008, 02:10 AM
Superpickel's Avatar
tell him better gas mileage
Superpickel is offline
Old 05-28-2008, 02:11 AM
Yeah I told him that, but then he talked to the dealer and the dealer said that it gets less mpg becuase it increases the HP.
Can u explain how it has better gas mileage?
Thanks
Old 05-28-2008, 02:22 AM
I have a Fugita and I don't really get better gas mileage because I love the low rumble of the CIA. Always hard on the gas. Here recently I've been shifting around 2700 RPM to attempt to save more gas. Also there isn't a significant change in HP at the wheels. If anything it is not a large gain by any means and should give you around the same gas mileage if not just alittle better. if you want a larger gain, there are some new spark plugs that increase gas mileage, more hp and more torque. they are on www.pulstarplug.com. the only set back is that they a 25 bucks a pop
Old 05-28-2008, 03:18 AM
nuke's Avatar
Thanks
The same way it increases power. Denser (i.e. more air) air entering. Better air-fuel mixture there for more efficient burn.
nuke is offline
Old 05-28-2008, 03:37 AM
Zebman's Avatar
Whos paying for the larger majority of the car? I try to respect whoevers paying my way, so this question should determine the outcome of your dispute.
Zebman is offline
Old 05-28-2008, 05:36 AM
ppiech2's Avatar
i noticed that i could get an average 25 - 30 more miles out of a tank of gas with my cai. Obviously depends on how and where you drive, but it did help.
ppiech2 is offline
Old 05-28-2008, 05:41 AM
Dkfung88's Avatar
double post...
Dkfung88 is offline
Old 05-28-2008, 09:51 AM
toyota_scion_tc's Avatar
www.trdsparks.com sells the injen with the bpv. You will need to cut the intake on both pipes to make it 100% functional and there is nothing to worry when you have a bpv except if you are using a K&N filter the oil will eventually get onto the MAF sensor causing problems but if you switch to the AEM Dryflow no problems. I had an injen on my car and around 18,000 my car started missing like I had bad fuel or plugs. I checked the plugs and everything else, but I could not figure out what it was. I bought some MAF cleaner by dumb luck cleaned it and no more issues. I had never cleaned the filter yet because it wasn't dirty yet.
toyota_scion_tc is offline
Old 05-28-2008, 08:22 PM
Would the hydroshield from innjen do a good enough job from preventing water to being sucked into the engine?
If not, does any one know where i can get the bypass valve for the injen seperatley?
Thanks
Old 05-28-2008, 09:23 PM
SengTC3's Avatar
CAIs are for losers, stock air box FTW!
SengTC3 is offline
Old 05-28-2008, 09:59 PM
bigwillystyle23's Avatar
x2!!
well mines a "modified" stock air box lol
no resonator or charcoal filter.
bigwillystyle23 is offline
Old 05-29-2008, 01:09 AM
Air2TheThrown's Avatar
cai? hydrolock? air box? dad? the?
Air2TheThrown is offline
Old 05-29-2008, 01:38 AM
joeya28's Avatar
hydro lock if your stupid, and i presume your not.. so no worries
joeya28 is offline
Quick Reply: Alright need helping convincing my dad for me to get a CAI
