Antifouler
Team Hamster
Per the header DIY in the tech section (I followed it yesterday when installing my Strup header and so far so good):
Originally Posted by Kaeon
*Note* The DC Header is known to make the 'check engine' light pop on, But no worries for $3.00 at your local Autozone Or Pep Boys you can fix this.
You will need a set of Spark Plug Anti-Foul's they are 18mm HELP! brand Part#42002 or 42009.
You will need to drill out a 1/2" hole in one of the Anti-Foul's
Unbolt your 2nd O2 sensor *NOT THE ONE ON THE HEADER, THE ONE ON THE S PIPE*
(I would spray a little WD40 on this o2 as well before removing)
Now screw on the Anti-Foul with the 1/2" hole on top of the regular one and then screw it into the hole for the 02.
Screw the 02 into the Anti-Fouler's tighten everything up, Then disconnect the (-) Battery terminal for about 1 minute.
And BAM no CEL.
~ Kaeon
And BAM no CEL.
~ Kaeon
autozone might sell somethin diff but i got from Mac tools (this is the only thing i bought from them and i like it) its a small hand held scanner for 60 bucks its great clears codes reads them and some freeze frame data. i use it when our shop scanners are tied up or i just have a non toyota car cuz the toyota scanner takes forever to scan a non toyota
theracingrhino
02-13-2015 09:49 PM
