Anyone Ported and Polished? Looking to go this route....
Hey i was wondering if anyone got their head ported and polished and if so what kind of hp did you see after the new cams and computer tune....I am looking to go this route in the next couple months and was wondering where you sent your head to get done because i dont want to send it to a place that has never dealt with a TC before..... Thanks
do you know of anyone else that has it done, it does not seem to be a popular mod, however i know having a head ported and polsihed is a huge increase in hp upwards to 60hp
Oh i know just a PnP head wont, but i mean i know my friend after he got the computer cams and Ported and Polished he mad an extra 55whp im not saying it will be the same for the TC however i know it makes great gains....It also runs around $2000+
Team No Limitz
i was planning on getting cams did not know how many were available, and wanted to get a piggyback system, and it was a variable valve timing car, it was a civic with a gsr motor....I basically want to know is does anyone have this combonation and what are the numbers it puts out before i shell out the 2500 bills for it, thank you for input on toyotas already well flowing heads...
If your going to go through port and polishing just get a higher compression piston thats where you'll see your power anyway. As for cams Brian Cowler told me they should have cams for the 2AZ out by next summer, but with 11:1 compression pistons, PnP heads, cams and a good tune you can see 40-60 pretty easy.
I have P&P a head on a tC before. You wont have to much gain in HP unless you have a good piggyback ECU and the usual I/H/E additions. The main reason why i would do it if i were you, is because the tC revs alot quicker with it on. The RPM's like to climb alot faster when accelerating.
I also am looking to port my head.
I don't have any problem with the actual porting but I'm a newb when it comes to cars.
questions:
what are my options for fueling changes?
can I really remove the head without pulling the motor from the engine bay (I'm not sure if I can see all of the bolts holding the intake manifold on)?
any tips on head removal would be greatly appreciated!
questions:
PnP, aem standalone, injectors, i/h/pulley, full 2.25'' exhaust, itb's and a damn good tune you should see 60-80whp
The over-all cost would be around $6,000-/+ including parts and tuning. Just the port and polish alone would only gain around 15-20whp if its done properly, but its virtually useless without any other mods.
The best single n/a mod would be itb's, youd see the highest gain for that mod compared to anything else.
well right now i have Intake, Pulley, 2.5inch Catback, S pipe, im looking to get headers and then piggyback cams and port and polish....Thank you for all the info so far
search for tcpete's setup,the tc's head isnt all that good from the factory its pretty rough,and the aem piggyback would work good for a n/a setup,not as good as a standalone,but for a mild setup it would be fine.
Anybody since this post pnp their setup? Im suprised more people haven't posted about this because it seems like a horsepower release that wouldn't be too hard (nothing complex, just a port that mactches the gasket up) - Or is my logic wrong? Someone with a lot more knowledge please comment. thanks.
Well i decided to pick up a Turbo Kit instead of going all motor
Kit detials are:
ZPI Stage 1 Turbo Kit
Evo 16g Turbo
Dezod FMIC
550cc RC Injectors PNP
Greddy Emanage PNP harness
Turbo XS Manual Boost Controller
38mm Turbo Concepts OPEN Wastegate
Apexi Turbo Timer
HKS SSQV BOV
Kit detials are:
Evo 16g Turbo
Dezod FMIC
Apexi Turbo Timer
HKS SSQV BOV
