Anyone use this ? (Greddy Intelligent Informeter)
Has anyone used this yet ? looks nicer than the Apexi one,
http://www.greddy.com/prod_informeter.htm
now I wish I did not get that CC gauge pod
http://hopupracing.com/grininfcosh.html
http://www.ptuning.com/html/Item-Des...niversal%20Fit
It says it can data logo also, it displays A/F, so if the front stock 02 sensor is a wide band. Would it read like a wide band ? if it does it would be a cheap wide band/data logger.
Bummer that it goes throught the OBD-II though... looks neet...
This is essentially an OBD-II display module. I have the same functions through my OBD-II interface with my laptop...
You can't tune with this, like the A'PEXi has the potential to do, so that's what differentiates the two in regards to function.
It'd be even better if it seemlessly tapped into the car's ECU, plugging into the OBDII will have the wiring by your left leg.
