Apex'i RevSpeed Meter Installed
I was suprised at how easy the install was - just power, ground, and tap into two wires in the ecu which is right under the glove box, to get tach/speedometer. I'm really happy with how it looks, and how accurate it is. I am still deciding where to mount it - I'll probably keep it where it is, i haven't drilled or made any permanent modifications, it just wedges into the compartment infront of the steering wheel, which is pretty much useless anyways...what do u guys think about that location?
For more info on the revspeed meter:
http://www.nlmotoring.com/cgi-bin/cp...g=prod&ref=430
i think it would look good there if you filled that area in with some kind of face-plate that accented or matched the dash color.....
i read the info on it on your web site, you have a lot of nice gear there!
btw, what do you use it for? i see it has a lot of functions.....thanx.....
Originally Posted by CuBiSm
Infiz,
do you have the wiring guide for ECU, cos i have a HKS Camp which i need to
wire up with into the ECU
Ryan
Originally Posted by sensez
infiz:
what do you use the LCD for?
fur_pig
03-20-2020 04:28 PM
TheRedBox
31
12-02-2003 04:53 PM
