Auto tranny issue
Auto tranny issue
So, my auto tranny is doing something strange. Shifting between 1 and 2, it would almost randomly suddenly drop RPMs to 2000 and hold there for a few seconds, then go back into my control. I figured at first I was hitting redline and it was a failsafe sort of thing, but then i remembered, it would just bounce on the rev limiter. so then i checked engine oil and tranny fluid levels, all normal.
only thing left? overheating. anyone else have this issue? know what it is? i know it wasnt some mechanical problem. it was distinctly electronic. only really happened while revving up.
it runs fine now.
which also brings me to... has anyone installed a tranny cooler? maybe from b&m?
it runs fine now.
yea that exact same thing happened to me. like if i were to drive shifting from 1 to 2, it would like high rev but not go in gear, then like it would go back in gear. so i just took it to the dealer, and they found out that it was a disc slip so they replace my trans for a whole new one for free.
I was recently on the freeway stuck in traffic doin about 45 and I found and opening and Put the Pedal to the metal and my car just revved to redline and did not engage a gear, I had to let off the pedal, let the car settle and then hit the gas again.
Same thing happened about a week later, I was coasting down a hill and puched the gas, the car just revved, totally loss power and then Launched into gear and threw me into my seat with a hard jolt.
Weird eh?
Weird eh?
i experienced a similar problem with my '01 civic... issues with the torque converter and the tranny was circulating fragmented clutch in the transmission fluid. have you been going from reverse to drive without complete stops? sounds like the transmission could be in trouble...
It is definetly possible I have gone from Reverse to Drive on a few occasions to peel out in a parking lot or something. Its not like an everyday thing though. Keep in mind that this problem started when I only had about 2k miles on my tranny.
I have thought that there may be metal shavings in the Tranny fluid from the original break-in period, However the dealer doesnt do tranny fluid flush changes during regular service intervals.
The only thing I wonder is... If I take it to the dealer, they are going to want me to re-produce the error with them in the car, and I fear I wont be able to do that since it happens on a rare basis.
wow that is super lame and definitely needs to go to the dealer. you KNOW something is wrong, so make sure they open it up and check it out.
ive probably done the reverse/drive thing before too. but my problem was nothing like that, and hasnt happened since the "overheat." hmmm
Weird eh?
Weird eh?
https://www.scionlife.com/forums/vie...288&highlight=
check it out. same post as u but a while ago lol
Thanks for the feedback. Did they tell you exactly what the problem was? This would probably help me out to tell them exactly what the problem is.
Drew
