Automatic Transmission Upgrade Info - ZPI SOLUTION
#121
Originally Posted by ScionDad
Originally Posted by miamibusta69
SO if i buy the harness from zpi all i have to do is plug in the harness to the ecu and then plug in the shift kit thing? will a camcon or a emange also just plug in when i get one?
If you get the harness, there will be 2 wires you will cut. Those 2 cut wires (4 ends) will wire right to the E.S.K. (4 wires). Then power and ground.
Emanage is same way to wire up, which ZPI can tell you that later if you're not ready for emanage yet. Camcon should also be the same way.
Dezod only had the prewired ones (ZPI does as well, but were sold out)...which is fine because I needed it anyway.
#123
Couldn't get the car since she had to work every evening this week. I will have it this weekend to make the mod.
The unit runs around $200. A harness also runs around $200 or so.
If you don't want the harness, you can cut 2 wires and save $200. I chose the harness because I am using emanage anyway.
#126
I got my harness from Dezod. However, it's not a straight thru harness. It is setup for emanage and some of the connections are broke without it. However, ZPI has straight thru harnesses...but they were out of stock when I needed it.
Sam at turboeast faxed me the connection sheet guys. WOOOHOOO.
I will have a full write up on this. Right now, I still haven't reinstalled my turbo because I want to test it without FI first. Get some video. Then install the turbo this weekend and compare the shift with FI.
can't wait for the videos
#128
Sorry, no update yet. I gatta have her give the car up for a weekend to redo everything and for some reason....she won't part with it yet. Not to mention is was friggin 5 degrees here for the last week. Space heater does little good in the garage at that temp.
I think I have it starting this Friday night...so should be good to go.
#130
Your wording made it seem (at least to me) that if you use the Emanage harness that you NEED the Emanage connected in order for the ESK to work...is this the case? I figured that since the harness just extends the wires from the ECU I can get a ESK now and then hook up an Emanage later. Which one is it? Thanks!
#135
The ZPI harness is a straight thru harness. They do the taps themselves. So, you can order them not needing Emanage taps.
#136
Hold on the E.S.K. from Turbo East.
When I installed it, the car was having trouble running right...but I was attributing that to the Harness and Emanage. Since them, I have been working to resolve the issue. But at this point, several other have got the kit and tapped direct and seem to be having problems running right.
Working it out now.
Working it out now.
#137
Working it out now.
Working it out now.
#139
Sorry to hear that ScionDad. I have been ill/hospital for the last week. Just sold my 96 Civic and saving up for any successful future tranny mods that come up. If it helps, Merry Xmas. If you would like to set up a testing fund, I am willing to contribute to the cause.
