B17/B18c1 vs 2AZFE
Big Sky Scion
B17/B18c1 vs 2AZFE
How do the GSR motors, both the B17 and the B18c1, stack up against our motor? And not really specwise, I've found that stuff, but on the track. Preferably, how it would work out installed in an older CRX, put up against a tC.
Originally Posted by Mightygnu
b18 in a hatch will destroy a tC.
we raced from a 15-25mph roll (advantage honda) up a hill (advantage tc). We were dead even through 2nd, i shifted to 3rd and started to nose ahead. by the top of the hill i was a good length or two ahead.
we went again on flat ground and it was closer but I still won.
weeks after he claimed that either his vtec wasn't working or he had a bad cylinder or some excuse or another....i forget. The car pulled pretty smoothly and hard, so i'm not sure about that. i think he was just jealous.
either way, i beat a b18 hatch.
there are a few possible explanations as i see it:
1) the motor actually did have a problem w/ vtec or a cylinder
2) the motor was old and probably needed a good tune up
3) while the gsr has more hp than the 2az, tq is about the same, given the fact that we were going up hill (which requires more tq) the longer stroke/torquier motor would have the advantage of being able to pull up the hill stronger.
4) the hatch driver is a fat kid (est. 250lbs) and he also had his brother in the passenger seat.
5) a 2az w/ i/h/e is probably making around the same power as a 10 year old 1.8 liter B18.
Originally Posted by TCpete
x3.. stupid thread... you cant compare these motors.. to many scenarios to choose from that are deciding factors...
if anything, i'd say to NA 4 cyl engines with less than 2.5L is a pretty fair comparo. albeit all theoretical.
no because u cant compare a 1.5 sohc non vtec to ours.. nor u cant compare an h22 vtec with ours.. both 4 cyclinder, both 2 pretty different motors..
yes, you can compare a 1.5 sohc non vtec motor to our 2.4 dohc vvti motor....... ours is bigger, better, more powerful and faster.
Big Sky Scion
a gsr in a crx, eg, del sol, or any other Honda would more than likely beat our TC's.
even an LS motor in an eg/rex would still beat out TCs. yeah our motors are makin more power and torque but like they said already, it a power to weight ratio, our cars are heavy, weighin almost 3k. a motor like a gsr, h22, k20/k24 or any other Honda motor in a lightweight car like an eg has the advantage over us. throw a b,h, or k series motor into a Honda and a few bolt ons like i/h/e and they'd smoke us all day.my friend owns a h22 eg with a 75 shot and he's running 13's all day and another on of my friends owns an eg with an ls motor with i/h/e and hes running low 14's.
some of you guys may feel differently but thats just my .2 cents I've been around Honda's and am friends with mainly Honda guys and see how fast a stock gsr and k series in their car is.
it's different.
i have both a tc and a crx with a swapped b18c type r.
the crx kills the tc but not because of mods, or engine, the 2azfe has way more torque than most honda engines, even some of the newest k-series, however it beats it because of the power:weight ration between the 2 cars which is way waaaaaaay different and you cannot compare the 2 cars.
on the tc i have intake, headers, custom midpipe, exhaust, engine mounts, vvt-i controller and the crx with the "stock" type r engine still kills it...
my tc is 2600lbs (weight reduction) and the crx is 1700lbs...
2 totally different scenarios.......
^^true but completely irrelevant haha.
B18c5 = USDM spec type R motor 195bhp
B18c1 = UDSM spec GSR motor 170bhp
Anyways, a fully functioning B-series motor in a featherweight honda driven by anyone under half a ton will take a mildly modded tC. Case closed
