Balance Shafts removed + light weight flywheel
Old 07-02-2008 | 09:54 PM
whippingpost's Avatar
Default Balance Shafts removed + light weight flywheel
Has anyone tried this? I'm doing it this afternoon. Yes, i know the risks for removing the shafts, so please don't flame.
Old 07-02-2008 | 09:59 PM
2_much_tc's Avatar
good luck?
Old 07-02-2008 | 10:06 PM
TCpete's Avatar
im watching this one... remember to plug the right oil squirters....!!!
Old 07-02-2008 | 10:31 PM
terminal's Avatar
do pulling the balance shaftes actually help? it just made my turbo d16 shake like hell... thats why i reinstalled them... silly honda kids, i know!
Old 07-03-2008 | 01:57 AM
ESEMRFOZZ13's Avatar
thier is a post in S.L. where this has been done and i do believe they had a gain, search and repost if you find it.
Old 07-03-2008 | 02:25 AM
Mid_Life_tC-risis's Avatar
6whp gain ... decide for yourself if it's worth it
https://www.scionlife.com/forums/viewtopic.php?t=187387
Old 07-03-2008 | 12:57 PM
I did it. Everything went really smooth and yes I plugged the oil galley. I definitley notice qucker acceleration through all the gears and it revs soooo much faster now. The only downside i see so far is the revs drop very quickly, especially with the ac on, so you have to shift alot faster. It's really not that bad though. As far as the vibration goes, i have poly motor mounts, so my car vibrates anyway. If i run into any problems i'll let you guys now.
Old 07-03-2008 | 01:31 PM
TCpete's Avatar
keep us posted... do you have pics of which galleys you plugged?? i wanted to get this mod done... but forgot which gelley it was.. how long was the tear down?? good job so far... dyno that thing!
Old 07-03-2008 | 02:09 PM
It only took a couple hours for the teardown, but the longest wait was for the rtv sealant to cure over night. I'm actually gona try very hard to do a DIY for the balance shafts removal this weekend. I snapped a bunch of pics yesterday, so i just need to write it up. I know alot of people would like a DIY for this. 1st gear traction is almost nill. Guess my next mod will be some sticky ___ tires! looking to dyno by the end of the month. I'll keep everyone posted thanks.
Old 07-03-2008 | 02:24 PM
TCpete's Avatar
sweet.. +1 for you on this... would love to see a DIY... how come u used rtv sealent and not just a simple tap and dye and run a bolt to plug it?
Old 07-03-2008 | 02:38 PM
Actually i used the sealant for the oil pan gasket. For the oil galley, there is a bolt hole right beside the galley for the shaft "case". I cut a 2 inch strip of aluminum and drilled a hole on one side. i stuck the bolt through the strip and torqued it down. it kind of makes a plate that covers the galley and the bolt keeps it tight, so it wont leak. i also made a 2 inch "snake" out of jb weld and pushed it up in the galley before i bolted the plate down and also used loc-tite on the bolt. There is now way this thing is coming out. It's kind of hard to explain, so i'll try to get some pics posted for you.
Old 07-03-2008 | 06:28 PM
caveman's Avatar
1UP Crew
watching!...
Old 07-03-2008 | 11:21 PM
I don't know why i forgot to mention this earlier, but i also have the NST underdrive crank pulley along with the flywheel and balance shaft removal. I know that is ALOT of weight taken off the rotating assembly. My next question i guess is i've been thinking about purchasing the rest of NST's pulley kit (water pump pulley and alternator pulley). If i do get the rest of the pully kit, do you guys think that would be too much? Don't get me wrong all 3 mods i've done so far(pulley, shafts, and flywheel) have made a HUGE difference, but like everyone else on here i'm always looking for more. Any thoughts?
Old 07-03-2008 | 11:22 PM
and yes i use 5 quarts of oil now instead of 4
Old 07-07-2008 | 06:47 PM
TCpete's Avatar
any updates?
Old 07-08-2008 | 02:23 AM
unxpectederror's Avatar
watching
Old 07-08-2008 | 03:38 PM
yellowxhoodie's Avatar
watching for that write up.
Old 07-09-2008 | 04:52 PM
I made a little video on my phone of how much faster the engine revs now that i removed the shafts, I can't get it to play on the computer. Can anyone help me post a vid?
Old 07-09-2008 | 05:43 PM
you should be able to upload it to youtube.. give that a shot
Old 07-10-2008 | 09:56 PM
here you go guys
http://www.youtube.com/watch?v=ZA-c1Xn6fbA
copy and paste
Quick Reply: Balance Shafts removed + light weight flywheel
