Battery Install. Now CEL, Car Stalls and Won't Give Gas? Help
Old 02-17-2010, 10:23 PM
FlintMica2005's Avatar
Default Battery Install. Now CEL, Car Stalls and Won't Give Gas? Help
So I installed a new battery, and now all of a sudden the care won't stay on unless I give it gas and in idle stay under 500 rpm, when I punch it for gas it cuts fuel immediatly and CEL came on?
I have a SRI so im thinkin it has to be something like that? IDK?
please help anyone! im struggling now I cant even drive to work. should I let the car ECU reset? what the hell should I do?
FlintMica2005 is offline
Old 02-17-2010, 10:28 PM
sw09's Avatar
did you disconnect something then forget to connect it again?
sw09 is offline
Old 02-17-2010, 10:31 PM
BZinn1's Avatar
is your MAF hooked up or perhaps a vacume hose got pulled off,but check wires,unhook battery,let sit,rehook and let idle for 5 min to relearn map.
BZinn1 is offline
Old 02-17-2010, 10:33 PM
tried leaving the car on and it just idles really horribly under 500 rpm's
Old 02-17-2010, 10:45 PM
bzinn nothing was moved just disconnected the battery put a new one and that's it, you think maybe I have to let it sit and just idle out to relearn? I drove around before and it idled fine after awhile but punching it made it boggle.
maybe I just have to let it idle and relearn it?
Old 02-17-2010, 10:52 PM
so im gonna turn it on and let it idle again. even if its idling unde rlike 500rpm and struggling to stay one?
cburglb34's Avatar
i think u blew a fuse....an important one so start testing them lol
cburglb34 is offline
Old 02-17-2010, 10:57 PM
so I had the car off for like 15 mins turned it on and idles great now, but I try to give it gas and its not doing anything its notaccelerating nothing?
Old 02-17-2010, 11:14 PM
Old 02-17-2010, 11:16 PM
DJ08tC's Avatar
has to be some fuse or something. that is strange..
DJ08tC is offline
Old 02-17-2010, 11:21 PM
I checked all of them all of them are perfect. I need to connect it to a scanner ands see wat the code is
its bugging me out, now the gas was buggin out and now its fine
Old 02-18-2010, 02:52 AM
jbae1221's Avatar
did you accidentally hit the pos of the battery on the sri?? I did that and shorted the maf... sounds like you need a new maf
jbae1221 is offline
Old 02-18-2010, 03:33 AM
that actually sounds like it could have happened. my friend (toyota mechanic) laid it down it probably touched the pipe of the intake. wow I never knew that could happen? so you say your MAF sensor died out? im taking it in to toyota tomorrow morning he's gonna fix it for me. ill see what's the deal. but thanks man!
Old 02-18-2010, 01:56 PM
Cars at toyota. and the MAF sensor was shot. so new one was installed and CEL is gone. so that's the first thing.
now the car still doesn't want give gas. I can cruise and go up to speed slowly and normal (60-65 on hwy) but lets say I wanna punch it to get on the hwy with a lot of speeding cars, ill punch it and it will boggle bc of giving it to much gas and when it does I try to keep my gas peddle down and it just won't go anywhere till I let it go and slowly rise the rpms..wtf??
Old 02-18-2010, 02:10 PM
cburglb34's Avatar
again...id check fuses...did u check the BIG fuses the ones that require a meter to check, because all those small ones are useless
Old 02-18-2010, 02:29 PM
idk its at toyota now, so im hoping they check everything. last nite we were checking all the tiny ones and the EFI one. but ill definatly send my friend a text to tell them to check it.
another guy at toyota said to clean the throttle body sensor or throttle body itself? idk wtf that's about. but you say to check the big square fuses in the fuse box?
Old 02-18-2010, 03:22 PM
highvoltage1's Avatar
that does sound like a throttle body cleaning issue. I woulda thought it was the MAF but since that was fixed and your still having problems I am wondering if and ECU isssue arose from frying the MAF? Maybe a slight possibilty. What intake is this? could it be an ebay intake that the pipe diameter is way wrong for the model year tC you have? just some ideas to help get the thinking process going.
highvoltage1 is offline
Old 02-18-2010, 03:24 PM
ElevationTC's Avatar
bad ecu? or leaking maf..
maybe vacume leak..
ElevationTC is offline
Old 02-18-2010, 03:26 PM
gotta love "friends"
Old 02-18-2010, 03:28 PM
expecially since the maf was plugged in! 12 volts the ecu input... ouch
Quick Reply: Battery Install. Now CEL, Car Stalls and Won't Give Gas? Help
