Best Manual Transmissino Fluid.
Sorry if this has already been posted, I only found threads about autos.
What is the best manual transmission fluid. It is time for me to change mine. I've heard that Redline MT-90 and eneos are both good. Comments.....
Did you use redline mt-90? That is not designed for use with syncro's and transaxles... thats why we have issues is what i've heard. the mtl is designed for use with syncros and transaxles.
IDK where you heard that but it is completely wrong, i use MT-90 and I love it, Motul is also very good, but dont use MTL it is too light
I personally run Royal Purple 75w90, but whatever the heck Toyota uses as the stock fluids will work fine unless you're under anything other than "street" settings...which you're probably not. Even under the occasional drag visits, you're likely good with the stock fluids.
ANY 75w90 will technically work. If someone says they can feel a difference, they're probably lying.
We personally run Motul Gear 300 in our cars without issues.
http://www.dezod.com/pd-motul-1l-bot...uid-105-qt.cfm
torqueTc
08-26-2015 04:20 PM
