Best s pipe for the tc
Originally Posted by Souljah347
Originally Posted by HOLLYWD69
Originally Posted by rrimportracer
whats the pro-motion site?
I got the creative compacts one.
No problems from the pipe. The O2 sensor itself has very delicate tread, and has fallen out before. Be sure to seal both ends and the O2 sensor in with RTV silicone (<$5 at autozone, the red stuff) and you should never have a problem'
In addition, all spipes have the potential to cause a slightly rougher idle. This is due to a change in how exhaust flow goes over the O2 sensor. I've had it on occaision, but it's not that bad.
i have a CAI and the DC racer header and planning on geting the Hks High-Power Exhaust and i was just wondering what could i buy to quite down the exhaust so it won't sound all nasty and raspy. i lvoe that deep rumble of the exhaust and i feel like when i get it i mgiht have this high pitched noise
Re: dummy question....
Originally Posted by ryk
dummy question here:
Will aftermarket S-pipe fit onto OEM exhaust? Will this make any notable difference than current stock setup?
yes it will fit, difference ? not until u swap the header. the main cat is the biggest restriction
how does this s-pipe compare to the zpi s-pipe and others. do you (invidia) make the mid pipe like zpi?? cuz that would be very nice. and if you do you will it work with my hks hi-power exhaust??? Pray
Scion Noics
i have a magnaflow cat-back with a magnaflow resonator welded on and its pretty quiet. in fact it was quiet as or more quiet than stock. when i put the header on it opened back up and there is a smmmaaaaaaall amount of rasp at about 2900-3100 rpms. still doesnt sound as good as my old TRD did but oh well, im going for performance now.
I got the ZPI S-Pipe with the Alphawerks headers and it took my Dad a while to install it cuz it wouldn't fit right, but I recommened getting the MMW since it's headers and s-pipe all in one...
From my experience, the Invidia S-Pipe is great. The fitment was spot on. Took under an hour to remove OEM S-Pipe and the Invidia one installed in like 15 minutes. Just be careful removing and then re-installing the O2 sensor. It's a bit sticky. I bought through wesellcarparts. Got a great deal and they may still have an ad in the sponsered sales link for the same deal. It is a little rougher idling on a cold morning, but all in all I'm very pleased. Butt dyno can't tell a tremendous difference, but I'm sure it helped considering how funky the stocker is.
