big bore throttle body
Old 02-02-2007, 12:54 PM
  #141
jjos1's Avatar
Could be the throttle body is bad
jjos1 is offline
Old 02-02-2007, 12:59 PM
  #142
soros151's Avatar
Could be, already gave up on this. I have this kit now laying here until I see what to do with it.
soros151 is offline
Old 02-02-2007, 01:00 PM
  #143
deathbyc4's Avatar
could be that the ecu not used to the larger throttle body, and is not running right. just a thought.
deathbyc4 is offline
Old 02-02-2007, 01:11 PM
  #144
soros151's Avatar
Then why is it that there are other working units in tCs over at California? The first one did work.
soros151 is offline
Old 02-02-2007, 01:18 PM
  #145
deathbyc4's Avatar
broken canooter valve, or a loose nut between the sterring wheel and the seat. It's probably just a bad unit. is the throttle motor the same dimensions and mounts as the ones on the tC TB?
Old 02-02-2007, 01:33 PM
  #146
soros151's Avatar
That's what the kit is for, as for the plug, is EXACTLY like the OEM unit.
soros151 is offline
Old 02-02-2007, 02:32 PM
  #147
Keeshwah's Avatar
Would the OBD II port on the car help at all?
Keeshwah is offline
Old 02-02-2007, 02:44 PM
  #148
deathbyc4's Avatar
i meant the contoller itself not the plug. If you could swap it for the bad one from your tC TB.
Old 02-02-2007, 03:07 PM
  #149
soros151's Avatar
That was one of the options, but drilling of the ribbets is neccesary for the swap, I didn't want to risk part of my TB in the process.
soros151 is offline
Old 02-02-2007, 03:32 PM
  #150
Keeshwah's Avatar
For diagnostic purposes couldn't you use this to help determine what exactly is failing?
Keeshwah is offline
Old 02-02-2007, 05:48 PM
  #151
jjos1's Avatar
If you want to sell it pm me, I might give it a shot
jjos1 is offline
Old 02-02-2007, 06:30 PM
  #152
TC_by_TRD's Avatar
hey maybe the ecu its not used to so much air going in and you need a fuel upgrade or something you should have gotten a wideband air fuel ratio to see what was going on for those 3-4 seconds thats jus my opinion tho
TC_by_TRD is offline
Old 02-02-2007, 07:26 PM
  #153
soros151's Avatar
I have a wideband, and during those seconds it goes right along the stock 14.7 the ECU adapts for.
soros151 is offline
Old 02-02-2007, 07:45 PM
  #154
trdtcpr's Avatar
hope you get this fixed and working!!
trdtcpr is offline
Old 02-02-2007, 07:48 PM
  #155
soros151's Avatar
PM sent to jjos1
soros151 is offline
Old 02-03-2007, 05:38 AM
  #156
jive_turkey's Avatar
Did you reconnect your intake tube to your throttlebody before you started the car? If you didnt then the car will not idle because the computer cannot read the air going to the throttlbody because it hasnt passed through the air sensor. Im not trying to be a smartass. I'm just trying to help you troublshoot because im very interested in this mode too.
jive_turkey is offline
Old 02-03-2007, 05:42 AM
  #157
Old 02-03-2007, 05:43 AM
  #158
Old 02-03-2007, 11:39 AM
  #159
soros151's Avatar
...yes I did.
soros151 is offline
Old 02-03-2007, 02:54 PM
  #160
trdtcpr's Avatar
please try it again or contact the company to see if you could get some help from them! could you try with another RX8 TB maybe a friends RX8 can lend you for a few to see if it was a bad TB.
trdtcpr is offline
Quick Reply: big bore throttle body
