bottom end please help
Old 07-08-2009, 06:28 PM
CarbonXe's Avatar
Isn't this like the 9th motor you've blown?
CarbonXe is offline
Old 07-08-2009, 06:54 PM
nodsetse's Avatar
Originally Posted by vettereddie
Not familiar with the 2AZ, but on the 1NZ there isn't room between crank journals to pull the pistons, they have to come out top-side.
Thanks man, good to know...and what a bummer. Could be the same situation for the 2AZ, but I don't know.
nodsetse is offline
Old 07-08-2009, 08:53 PM
streetracer99x's Avatar
my 2nd im going on my 3rd now... should i just get a used one?
streetracer99x is offline
Old 07-09-2009, 01:45 AM
DJ08tC's Avatar
How are you blowing this many motors, with no FI at that?
DJ08tC is offline
Old 07-09-2009, 05:43 AM
TcPrincess's Avatar
i thought i read a post like this a few months ago. what are you doing to these motors? i would get a used one.
TcPrincess is offline
Old 07-09-2009, 11:16 PM
RSracer's Avatar
Originally Posted by nodsetse
Originally Posted by Windu
yes. either way you will have to pull crank. if its a rod you will have to pull the head too.
You can replace pistons & rods from the bottom, you don't have to pull the head, it's just easier if you do.
Thanks Toyota! (1NZ-FE from a 2004 Scion xB)
Can someone verify the 2AZ pistons will clear coming out the bottom?
FYI, one of our southern Maryland members had a similar issue, where he had crank walk and chewed into the journal. Saved himself a lot of trouble though rather than trying a repair he just bought a used long block and dropped it in after a compression check. Hasn't had an engine problem since. If you need to find one, use car part. Most salvage yards will ship and are pretty reasonable on price. Some even warranty the block for 30 days so you know you didn't get a dead one.
http://www.car-part.com/
Good luck with the repair.
Piston cannot come out the bottom end of the block... do not attempt to rebuild the engine with the engine in the car. that is a crazy idea especially with out valve chain cover.
RSracer is offline
Old 07-10-2009, 01:58 AM
Windu's Avatar
I would say pull it out and either take it to a professional for rebuild or pick up a longblock from a salvage yard. Cuz it seems to me that something is not right with the past two builds.
Windu is offline
k1114
43
03-01-2023 03:08 AM
Greg S
07-21-2016 07:28 PM
That_Kid_Ju
06-26-2015 10:57 PM
2012TC
02-17-2015 08:41 PM
toyotaisme
13
11-14-2003 01:37 PM
Quick Reply: bottom end please help
