Camry engine vs tC's
I got this from another Scion forum ..
"heres a not so mathematical formula
Camry 2AZ=tC 2AZ minus semi forged rods and ceramic coated piston tops
ive been inside both engines "
Does this mean the Camry's engine is better than ours ... or is ours better than their's seeing the fact they wanted to super Charge ours ???
the tc is slightly tuned version and pushes out a bit more ponies than the camry's engine.
and usually that emans the tC's engine's better since it pushes out more power. would you say something is crappier if it was less power?
Re: Camry engine vs TC's
camry 2az=tc 2az minus semi forged rods and ceramic coated piston tops
and yes the tC engine is a tuned version.. much better engine now i feel (than the version in the camry)
sIcKsCiOnS
DelMarVa
Scion Tuners
tC motor is better tuned/adjusted from camry motor
had some issues with it when first came out, but querks are worked out for us to enjoy
Originally Posted by jmiller20874
Hey Bandit.
Correct me if I'm wrong, but aren't the numbers of the Camry and tC the same (HP/Tq)? I thought the only difference was the close-ratio gearbox.
Now then the Rav4's 2AZ produces 1 more HP and 2 more Torque than the tC's 2AZ. That I wonder why.
Hey Bandit.
Well under further review, the Camry has 154HP and 160TQ, so the tC's is more powerful and the Rav4's is stronger than the tC's
Camry 2AZ < tC 2AZ < Rav4 2AZ
The Highlander has the same HP as the tC with the same torque of the Rav4 (160HP/165TQ).
sIcKsCiOnS
DelMarVa
Scion Tuners
hp/tq is same..yes....
im talkin bout the motor in its early years....it had issues, which is y im glad it got worked out when puttin it in the tC
