Camry V6 in a tC????
Old 09-06-2005, 10:59 PM
ElChupacabra's Avatar
Default Camry V6 in a tC????
As a Scion Salesman I see tons of Camrys and the occassional tC when I can get my district manager to allocate them to me. I also know the specs on both and got to thinking. Sometimes thinking can be dangerous and since today has been a brutally slow sales day ive been doing a lot. Does anybody know if you can put a V6 Camry engine into a tC?? Theoretically it should be possible. All the right specs are the same as far as I could tell in my short investigation into the idea. Just wondering if anybody has ever done the full investigation on the matter. V6+tC=FUN (aka speeding tickets and court dates)
ElChupacabra is offline
Old 09-06-2005, 11:33 PM
kungpaosamuraiii's Avatar
Well since you have the specs on both of them, try finding out how wide and how long the V6 is. And if the day is really slow for you than just pop the hood on both cars and look to see if you can find where the engine mounts where.
I'd rather wait for the IS350 V6.
kungpaosamuraiii is offline
Old 09-06-2005, 11:58 PM
jmiller20874's Avatar
Cost of V6 swap > cost of turbo.
jmiller20874 is offline
Old 09-07-2005, 12:08 AM
miraclecreator's Avatar
and turbo = early destruction of ur engine
miraclecreator is offline
Old 09-07-2005, 12:12 AM
Fm_Tc_In_Ma's Avatar
Its a toyota.
Fm_Tc_In_Ma is offline
Old 09-07-2005, 12:13 AM
The_Instigator's Avatar
Only if you drive it really hard all the time. Properly set up, turbo cars be very reliable. Many Subarus, Evos, Audis, Volvos, etc have turbos and run fine for many many years.
The_Instigator is offline
Old 09-07-2005, 12:36 AM
bblhed's Avatar
If you want to be sure just look at other cars that fit a similar engine to the 1.5 or a V6 similar to the Camry V6. If there is something that matches your in. Also check to see that the two Transmitions are interchangable. When you check, be sure it isn't a one way swap. eg You can use the 4 cil tranny on the V6 but not the other way around. You may find that you have to do a full drive line swap.
This is why I like RWD, full drive line swaps are easy. Easy being a relitive term.
bblhed is offline
Old 09-07-2005, 12:48 AM
XD40tC's Avatar
I think an engine swap would be more fun than just adding a turbo. Itd be a great learning experience and youd be pleased for quite some time when youre fooling people all over the streets. But I guess you could say the same for a turbo so its all fun and games.
XD40tC is offline
Old 09-07-2005, 02:51 AM
matty-tC's Avatar
you guys are nuts. the 2az-fe is a great engine and you want to get rid of it?
matty-tC is offline
Old 09-08-2005, 01:40 AM
Yes, I am nuts. Not afraid to admit it. Its not that I think the stock engine is bad. Like I said, I was really bored and thought about the swap as an interesting concept. Would be awesome if somebody had already done it.[/quote]
Old 09-08-2005, 01:48 AM
tcsciontist's Avatar
he's bored...
tcsciontist is offline
Old 09-08-2005, 02:00 AM
tCb00b's Avatar
Don't forget how much it will throw off handling due to the added weight of the engine. Isnt the tc already 59/41? just my 02
tCb00b is offline
Old 09-08-2005, 02:32 AM
87na's Avatar
someone will surely try it sooner or later... seeing as how the 2AZ is used in both the tC and camry, one would think that the V6 swap could be a possibility....
87na is offline
Old 09-08-2005, 03:07 AM
06tCguy's Avatar
I like my mom's camry..it's got the 1mzfe(3.0L), not the 3mzfe(3.3L), it still pulls pretty hard. 210hp 220ft-lbs. it would move the tC pretty well.
06tCguy is offline
Old 09-08-2005, 03:20 AM
lo_bux_racer's Avatar
I looked at this last spring. I guess I get bored more easily. Anyway, you have to go slushbox, you have to rewire a considerable part of the car, and it's unlikely either the OEM Scion axles or the OEM Camry axles will bolt up without issues. It might require some kind of hybrid on the axles alone to get into the car. Then, just looking at the orientation and layout of the V-6 made it appear just short of impossible for lack of room behind the engine in the tC. That was my take anyway, just doing a quick side-by-side comparison. I was pretty much finished anyway when the slushbox requirement jumped up.
lo_bux_racer is offline
Old 09-08-2005, 11:54 AM
06tCguy's Avatar
well, I get my tC today(w00t), so I'll be able to do more in-depth side-by-side comparisons if anyone would like.
06tCguy is offline
Old 09-08-2005, 01:56 PM
Stealth97's Avatar
Your response is misinformed, and totally incorrect.
Stealth97 is offline
Old 09-08-2005, 11:08 PM
whitexa's Avatar
Don't tell people that they are wrong if you don't plan to back it up with reasons or facts
whitexa is offline
Old 09-08-2005, 11:21 PM
bubblemyster's Avatar
true.
bubblemyster is offline
Old 09-09-2005, 01:13 PM
matty-tC's Avatar
how about people don't spout off at the mouth about turbo's destroying engines without facts or reasons to back them up?
matty-tC is offline
Quick Reply: Camry V6 in a tC????
