Cams for the TC?
Cams for the TC?
Some of my friends keep telling me that if I boost my TC I should get cams too, so I was just wondering if any company has or is making cams for the TC. Any help would be appreciated.
Your friends probably dont know what they are talking about. I read in Maximum Boost that usually the stock cams perform well enough for most street turbo applications. I mean you have to be realistic. Pce
Couldn't someone get some blank cams from Toyota and take them to a shop to do a custom grind? This was, people can try to figure out what would be better options to try and then try them and dyno them. Of course there would need to be a lot of discussing in order to come up with usable numbers.
Or maybe the VVTi makes it so we do not need new cams and I am thinking about older V8's.
A good set of cams is FAR from wasting money. Especially if you are doing a complete custom setup and not just bolting on kits. And even more important with a completely NA setup. With a good p&p head, intake, header, exhaust, good tuning system and a properly ground set of cams from a good shop you should be able to put some respectful NA numbers down. And before anyone adds the "you cant beat the FI guys NA" crap, that is not the point to start with. But I would say with the above mods you should be able to push close to the numbers the SC with stock pulley is with a wider powerband on top of that (which makes the peak number difference go away between the two). So for those that love building NA power they would be great. For those with FI it would be equally great.
If you REALLY wanted to do it all NA you could find some lightweight rods and pistons to increase the safe piston velocity (raise the redline) and get them at 11:1 compression. You would be turning some very nice numbers then. And again, if you did it right you could most likely be producing a wider powerband, which again is worth more than a higher peak number. I would love to see some guys pushing 200+ WHP completely NA. I know a few are already trying.
I did hear that Golden Eagle (forgive me if that is the wrong company) is working on some 100% new cams (no regrinds) for the tC, but not sure what is going on with them at the moment.
But yeah, those guys sound like they know nothing about the tC at all. Besides what some guys that have barely driven 4 bangers at all in thier life or are just starting to drive, most will tell you the car does well for its class power wise. It is no sports car, but is a good starting point for power. If you are looking at being the fastest street legal thing in a 1/4 mile at the moment you are probably not picking THE top choice to start with, but for that matter you arent picking the right drive train or number of cylinders either But the tC has plenty of potential to compete and to be a great street car.
VVTi only adjusts the cam angle (changes the overlap) so a new set of cams would be great to increase lift and duration. With that and some tuning on the VVTi system you could make some nice differences.
But I think cams would be the next logical add on once you figure out the boost platform you are going to use. I am sure some will be coming soon.
there was a topic out about this awhile ago. i'm sure darren or somebody will let us know when we will get cams. when they do come out then i might go the aaaall motor route. my civic was all motor that put down low 13s with a lil spray. i had a bullfrog cam in it which made it lope a bit like a muscle car, and some other goodies.
the con on cams r possible bad emissions.
Then the question becomes, would it have to be trial and error finding the right grind or could it be possible to use what is stock to determine a pretty good spot to start in?
And as far as how cams are NOT a waste of money, putting a cam in a close to stock LS1 can gain 40-50rwhp. Putting one in the boosted ones gets soooo much more.
AND you can make your car have a bad ___ lope!
In a turboset up I think "overlap" is not as desirable compared to a NA set up.
Cams aren't a bad idea. But with the valve technology etc going into cars now. Depending on your applications you get varried gains.
I will be building a custom tC soon enough, after I return from basic training. I can assure you that I will have some custom cam's ground for me through a buddies shop. It will cost me a good amount, but I am sure that they will sell. Mine will be FI (turbo) but again, custom setup, built block, reliability. When it happens, i will share.
Originally Posted by Bsmntcuts
I wish they had a cam out. When the hell are they going to come out with an intake manifold/fuel rail?
Originally Posted by blackonblacktc
no cams out yet...and dont listen to your friends, let me guess...they are honda boys?
I talked to kenny abotu thsi a few days ago and he said that right now for n/a people its not worth it on the tC. As far as F/I the are being built and should be out sometime this summer. thats all i know.
