cel
cel
my cel came on today. so i took it to get it checked by machine for free at autozone and they said i was lean. so they turned my cel off. what does this mean how do i fix. also my scion has a wierd smell when the engines hot and i get out, not bad or ne thing but is this normal... thanks
What is the exact fault code they read? (Have seen others use non-Scion tC references which of course lead to an incorrect diagnosis.) Once you know the exact code you can research it in the Tech section here.
Also the wierd smell could be the sulfur-like odor given off by the catalytic converter in the exhaust manifold, this is not unusual.
maf is mass air flow sensor, and it is the little black box screwed into your intake, if thats thats the problem you need a new MAF. I highly doubt it is an injector, and for the leak you need to just have a mechanic check the car for leaks, but it is probably the MAF, it usually give is self away by affecting both banks of an engine at the same time, but since the scion is a 4 cyl only way to tell is to have it checked
new MAF is fairly expensive, if your car is still under warranty, take it in, and whatever they find wrong will be under warranty.
take it to your dealership, tell them what code you found, they may want to test themselves, after that, they will perform a series to tests to determine the problem and fix it.
Scion Tuners
Originally Posted by silverstreaktc
just put some crack in the gas tank and gain 35whp
