CEL/O2 sensor help
Old 09-28-2007 | 01:14 AM
josh4201's Avatar
Default CEL/O2 sensor help
Has anyone w/ I.H.E setup ever had problems with the O2 sensors?
I have mmw header, injen intake, magnaflow exhaust. The header has about 20k on it and never have had any problems.
Two days ago my CEL came on and i just got around to getting it checked. Went to autozone and they said it was the first O2 sensor that was the problem. (I cant remember the exact code reading.)
So i took the sensor out and cleaned it w/some brake cleaner, let it dry, reset the ecu and still have the CEL.
Do you think it (O2sensor) could be bad? If so could it come from the ecu feeding too much fuel cause of the i/h/e setup?
Im going to go to advanced auto tomorrow and get the actual reading on paper.
Also........I have the CEL eliminator on that comes w/the header/s-pipe
Thanks in advance for the help
Old 09-28-2007 | 03:21 AM
hawgs74's Avatar
Check the one on the s-pipe too. I had a weld break on mine which caused a small air leak and a CEL. Had to take it off and re-weld the bung. Not so happy with weapon-r right now
Old 09-28-2007 | 12:58 PM
theslayer's Avatar
Old 09-28-2007 | 06:23 PM
Mid_Life_tC-risis's Avatar
Get the exact CEL trouble code so there is no confusion. Then research the code here:
https://www.scionlife.com/tech/manual/?manual=tc05_0227
Old 09-29-2007 | 01:30 AM
josh4201's Avatar
I got the exact codes now here they are.
DTC (codes)
P0136
O2 Sensor
Circuit Malfunction
(Bank 1 Sensor 2)
DTC Pending (Codes)
P0136
O2 Sensor
Circuit Malfunction
(Bank 1 Sensor 2)
Now I hope that I dont have any broken welds or leaks. Im going to change my oil tomorrow and i will probly remove the s-pipe and check it out. Do you think that carbon deposits could block the sensors from reading the exhaust wrong?
I tryied to call weapon-r today but the guy i needed to talk to (Chris W.) was at a car show and wouldnt be back till Monday.
I was going to ask him if they had seen anything like this before.
Old 09-29-2007 | 03:42 AM
hawgs74's Avatar
Sensor 2 means its definately the one on the s-pipe. U need to limit ur driving because ur car is running rich now. I wouldnt reccommend any 50+ mi trips till u get it fixed. It is also possible that u burned up the O2 sensor. In that case u will need to order another from the dealer. But check that s-pipe first.
Old 09-29-2007 | 04:07 PM
No he's not running rich, there's separate trouble codes for running rich and running lean. This would be a big deal if it was the AFR sensor (Sensor 1) on the header.
This is not a serious problem at all. Sensor 2 is used only to monitor the efficiency of the catalytic converter in the stock exhaust manifold. Since you've replaced it with the Weapon-R header, there's some issue with the CEL eliminator.
Old 09-29-2007 | 05:54 PM
josh4201's Avatar
I have found the problem. The O2 sensor bung on the s-pipe has a crack in the weld about half way around it. Just like hawgs74 said.
Im deffanatly not too happy w/ weapon r now. Going to call them monday for sure and hope the will pay for the cost to get it welded or send me a new pipe.........probly not going to happen though.
What sucks even more is i work in a steel fab shop and have access to welders, but we do not use stainless steel
Old 09-29-2007 | 06:20 PM
Yes the fact that it's happened at least twice shows there's definitely a weld quality defect with these s-pipes. MMW/Weapon-R has a history of some poor customer service, hopefully you will fare better.
How long is the warranty period and how long have you had the header?
Old 09-29-2007 | 09:18 PM
josh4201's Avatar
Not sure how long the warrinty is for the header and s-pipe. Ive had them installed for about 1 year, and about 20k miles
Old 01-09-2008 | 04:08 AM
mengsta's Avatar
Is there an update Josh?
Old 01-09-2008 | 11:18 PM
josh4201's Avatar
Yes there is an update.
I talked to Chris W. at MMW and he said that they would fix it for me. So i sent the s-pipe to him and in about a week i had the pipe back on the car and the car runs fine now. They were very understanding about the problem i had, and seemed like he wanted to fix it as fast as possible.
FYI/ I dynoed my car...........163 hp 162 tq
Old 01-10-2008 | 05:57 AM
mengsta's Avatar
O thats cool, they couldnt pay like restitution? for that one week of not being able to drive my car would ____ me off! Did they atleast pay for the shipping cost, of you shipping to them? and WOW all you have is injen short ram with MMW headers?! coppin 163 hp without a tune (m i right?) is nicee.
Old 01-11-2008 | 12:45 AM
josh4201's Avatar
I pay for shipping to send they pay shipping to return. I put the stock header back on till i got it back, about a week. It sucked bad to have the stock header and s-pipe back on.........my magnaflow exhaust was very quiet compared to when the mmw header was on. It was a little louder than the stock but not much.
Know i just have to figure out how to post my dyno results so everyone can see the torque curve and the a/f ratio
Old 01-12-2008 | 02:12 AM
mengsta's Avatar
Aww they should pay you back the shipping.
Old 05-16-2012 | 02:32 PM
r2d2michael's Avatar
sorry to bring this wayyyy back from the dead but hows the new pipe working? i bought the s pipe from them in 2011 and now getting the p0136 code. was going to look at welds also.
MeDizzy
10-08-2015 04:31 PM
vi3tb0i09
09-23-2015 09:32 PM
prescottn
09-22-2015 02:30 PM
gqdabien
09-17-2015 10:23 PM
Topfueltom69
09-06-2015 06:25 PM
